Updating a template through import
  • hardtofi
    • Jan 2008
    • 32
    Ran into a bit of problems while importing. Not sure if I'm doing something wrong or if it's an 1.4.4-issue
    The scenario is:
    I have a template with ~100 items and I need to reorganize what "applications" they are linked to. There are only two applications and the template is only used by one host.
    When doing import everything looks like it's working:
    # Added new application Template_mytemplate:Repository
    # Added new application myserver:Repository
    ... [bunch of items added, two rows for each item, one for host and one for template]
    # Added new application Template_mytemplate:Seeds
    # Added new application myhost:Seeds
    ...[more items added and the triggers]
    # Host [Template_mytemplate] updated
    However, when I check the latest data for the host, or configuration->items for either the host or the template, none of the items are in the applications I added. The applications are there but the values are not a part of them.
    If I manually change one of the items to be linked with an application is that reflected on the host using the template. I've also tried importing the template to another 1.4.4 server that i run locally and then the items in the template gets linked correctly.
    So I guess my question is: Is there some special trick I have to do when updating the item applications when the template has children?
