configure: error: Not found mysqlclient library
  • lwk
    • Jan 2008
    Hi!
    Im trying to install Zabbix 1.4.5 on an HP-UX 11.11 System-
    During :/configure the followning mistakes happen:
    checking for mysql_config... /usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/bin/mysql_config
    checking for main in -lmysqlclient ... no
    My configure was:
    configure --with-mysql=/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/bin/mysql_config \
    --with-net-snmp --enable-server --enable-agent
    MySQL Version is 5.1.23 64 Bit
    I tried to path the needed librarys via LDFLAGS but because of this the C Compiler gets an Error...
    Does anybody know, how to include the needes librarys in configure?
  • trikke
    • Aug 2007
    • 140
    I think u just have to include the PATH "--with-mysql=/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/bin/".
    See config.log for more information,
    Greets
    Patrick
    • lwk
      • Jan 2008
      Hi!
      Again, the same error occured...
      But the directory / path
      contains only binaries- no libs...
      • lwk
        • Jan 2008
        Does anybody know a solution?
        • maxpower
          • Jul 2007
          • 31
          look in config.log for the detailed error message as trikke already told you.
          • xs-
            • Dec 2007
            • 393
            try --with-mysql=/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit
            Normally you would enter the base path of the installation
            if that doesnt work try
            CPPFLAGS=-I/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/include LDFLAGS=-L/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/lib ./configure bla bla
            and
            CPPFLAGS=-I/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/include LDFLAGS=-L/usr/local/mysql-5.1.23-rc-hpux11.11-hppa2.0w-64bit/lib make all
            • Bill Wang
              • Jul 2010
              • 66
              1. find location of mysql lib dir and enter it
              2. there maybe have some lib file such like "libmysqlclient.so.15.0.0" and "libmysqlclient_r.so.15.0.0"
              3. make two soft links by run these two commands "ln -s libmysqlclient.so.15.0.0 libmysqlclient.so" and "ln -s libmysqlclient_r.so.15.0.0 libmysqlclient_r.so"
              4. then redo configure script
              • Ben B
                • Aug 2012
                You guys may find this one interesting too!
                It appears that if you're on RHEL or CENTOS; libmysqlclient.a is no longer supplied and will break the "conftest" stage....
                • malayo
                  • Feb 2013
                  • 9
                  fixed?
                  I too, I'm having the same issue on centos 6 with zabbix 3 source.
                  Have anyone fixed this?
                  • RTorrent
                    • Mar 2017
                    install mysql-devel
                    #yum -y install mysql-devel
                    you'll probably also need to install other packages needed later on.
