Traffic on interface eth0 not move
  • ChomK9
    • May 2005
    Hi All,
    I use ZABBIX 1.1alpha7 for my server pool(RedHat 9.0, Fedora Core 2, Core 3) and I've few problems.
    1. On The Zabbix Server (Fedora Core 2) -- Messege "configure: error: Invalid NET-SNMP directory - unable to find net-snmp-includes.h" appears while run command "./configure --with-mysql --with-net-snmp". I installed net-snmp-5.1.1-2 & net-snmp-utils-5.1.1-2. Then I used only "./configure --with-mysql".
    2. On The Zabbix Server (Fedora Core 2) -- Incoming & Out going traffic on interface eth0 isn't changed. see below
    3. But on The Zabbix agent (RedHat 9) -- Incoming & Out going traffic on interface eth0 is moved. see below
    4. I can't monitor MySQL "Not supported by ZABBIX agent".
    I need your suggestion.
    Thank you for very good monitoring tool,
    Chom Siripanich
    Department of Primary Industry and Mine
