UserParameter with Error "not supported"
  • Wal
    • Feb 2008
    • 13
    Help-me!
    I am configuring one "UserParameter", following line in zabbix_agentd.conf (for test):
    UserParameter=mysql.ping,/usr/bin/mysqladmin -uzabbix -ppassword ping |grep alive|wc -l
    Log in zabbix_server.log
    7289:20080505:113149 Parameter [mysql.ping] is not supported by agent on host [lippy] Old status [0]
    Executing in console by user zabbix:
    zabbix@lippy:~$ /usr/bin/mysqladmin -uzabbix -ppassword ping |grep alive|wc -l
    1
    Key utilized in item:
    mysql.ping
    Message by interface web:
    Error: Not supported by ZABBIX agent
    Status: Not supported
    Scenario:
    Server zabbix running "ZABBIX Server (daemon) v1.4.4 (17 December 2007)"
    Client zabbix running "ZABBIX Server (daemon) v1.4.4 (17 December 2007)"
    O.S.: Debian Etch
    My idea is use others Parameters, with others services, i'm executed tests for one homologation.
    Thanks for any idea!
    p.s.: My english is bad.
  • Wal
    • Feb 2008
    • 13
    Solved
    My problem is solved!
    • mikecrowe
      • Dec 2007
      • 34
      How did you solve this? I'm seeing a similar problem.
      • Wal
        • Feb 2008
        • 13
        Hi mikecrowe!
        My sintaxe was incorrect; I utilized one sintaxe corret and then solved.
        By, good luck.
