New Media types do not work
  • snailgame
    • Apr 2008
    • 13
    hello all:
    I install zabbix 1.4.5 in centos 5.1 (vmware)
    all work well but New Media types
    i have a script in /home/zabbix/bin/ called sms (it's software can send me the sms)
    i set the actions and see HISTORY OF ACTIONS
    all the messages are sned bu i did not receive one
    thanks for answer
    (I am sorry my english is very poor)
  • Niels
    • May 2007
    • 239
    You could look in the Zabbix server log, but I don't think you'll find anything there as the event list already showed that the messages were sent. It doesn't look like a Zabbix error. I suggest you modify your sms script to log what it's doing.
    • snailgame
      • Apr 2008
      • 13
      thanks
      this is my script
      ./sms -f <username > -p <mypass> -t "$1" -m "$2,$3"
      i do not see anything in the zabbix_server.log about the char
      • Niels
        • May 2007
        • 239
        Try using the full path for sms. Make sure it's accessible for the zabbix user.
        • snailgame
          • Apr 2008
          • 13
          ok I'will try it
          i have another question
          i see the manual the Action have an option "repeat" but i can no see it on my webconsole
          • snailgame
            • Apr 2008
            • 13
            Thanks Niels
            All errors by the sms's path
            i give the full path in the script all solved
            but in Action attributes:I can not find below options to set
            Repeat Send repeat messages. ZABBIX stops sending
            repeated messages if the trigger changes its status.
            Number of repeats Number of repeated messages to send.
            Delay between repeats Delay (in seconds) before sending next repeat
            message.
            • Niels
              • May 2007
              • 239
              Zabbix no longer supports repeated actions. It says so in paragraph 2.2, but the writer didn't remove the instructions you've read. Repeats will apparently be back in 1.6.
              • snailgame
                • Apr 2008
                • 13
                faint
                just wait for 1.6
                but i think it should be supported before 1.6 released
