"No such monitored parameter" when adding new trigger
  • goony
    • May 2008
    Zabbix V1.4.5, compiled & installed on Solaris V9, new Zabbix user.
    I've looked through the docs and maybe I'm missing some kind of fundamental concept: I want to create a trigger to fire if a particular named process is missing. This process isn't one of the default missing process triggers (inetd, sshd, syslogd, etc.) that are part of the out-of-the-box Zabbix install.
    On the Zabbix server, I'm in Configuration-->Triggers and choose an existing trigger that looks like this:
    Name: Inetd is not running on {HOSTNAME}
    Expression: {myclientroc.num[inetd].last(0)}<1
    So... I figured I could just clone the above trigger and modify the inetd part to become the process name that I wanted, but no dice - I get this error when trying to save the new trigger:
    No such monitored parameter (proc.num[nsrd]) for host (myclient)
    Do I need to modify my /etc/zabbix/zabbix_agentd.conf file to define something so that I can have a trigger fire when process nsrd is missing?
    Thanks!
  • nelsonab
    • Sep 2006
    • 1233
    It's likely you forgot to add proc.num[nsrd] as a key for the host "myclient". I know it seems counter-intuitive but that's how it works. Pretty much everything is centered around the key field.
    RHCE, author of zbxapi
    • goony
      • May 2008
      Closer, but still no joy.
      On the client system, added to /etc/zabbix/zabbix_agentd.conf:
      UserParameter=proc.num[nsrd],/usr/bin/pgrep -x nsrd|wc -l
      Restart the agent; get an error:
      bash-2.05$ /usr/local/sbin/zabbix_agentd &
      [1] 28874
      bash-2.05$ zabbix_agentd [28874]: Warning: Can't add user specifed key "proc.num[nsrd]". Incorrect key!
      Any further suggestions?
      Thanks!
      • boy01
        • Dec 2007
        • 24
        [1] 28874
        Thanks!
        I've found out that I can't use [] chars in my UserParameter specs.
        So I'd change your example to:
        UserParameter=my_proc_num_nsrd,/usr/bin/pgrep -x nsrd|wc -l
        • nelsonab
          • Sep 2006
          • 1233
          You're getting close. You'll need to go back to some of the basics. As much as I rail against it the manual is a good reference here.
          In your zabbix_agent(d).conf file try this
          UserParameter=my_proc_num,/usr/bin/pgrep -x $1|wc -l
          Then go to config-> host and setup a host entry for this machine.
          Then go to config->items and setup an item entry.
          Desc: Number of NSRD processes running
          key: my_proc_num[nsrd]
          type: number
          interval: however often you want
          store as: as is
          Now go to Monitoring->latest data, select the host, you should now see the item you just added in this list. Now this key is ready to be used in a trigger.
