На свежий CentOS 6.5, согласно инструкции (https://www.zabbix.com/documentation..._from_packages) устанавливаю заббикс:
Добавил репозиторий, он добавлися, но когда пытаюсь установить сам заббикс yum install zabbix-server-mysql zabbix-web-mysql
Получаю ошибку:
Делал:
yum --enablerepo=zabbix clean metadata
yum clear all
yum update
Получаю ошибку:
Total download size: 6.1 M
Installed size: 30 M
Is this ok [y/N]: y
Downloading Packages:
(1/4): zabbix-server-2.2.6-1.el6.x86_64.rpm | 20 kB 00:00
http://repo.zabbix.com/zabbix/2.2/rh...l6.x86_64.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
Trying other mirror.
(2/4): zabbix-server-mysql-2.2.6-1.el6.x86_64.rpm | 1.5 MB 00:11
(3/4): zabbix-web-2.2.6-1.el6.noarch.rpm | 4.5 MB 00:23
http://repo.zabbix.com/zabbix/2.2/rh...l6.noarch.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
(4/4): zabbix-web-mysql-2.2.6-1.el6.noarch.rpm | 13 kB 00:00
Error Downloading Packages:
zabbix-server-mysql-2.2.6-1.el6.x86_64: failure: zabbix-server-mysql-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
zabbix-server-2.2.6-1.el6.x86_64: failure: zabbix-server-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
zabbix-web-mysql-2.2.6-1.el6.noarch: failure: zabbix-web-mysql-2.2.6-1.el6.noarch.rpm from zabbix: [Errno 256] No more mirrors to try.
zabbix-web-2.2.6-1.el6.noarch: failure: zabbix-web-2.2.6-1.el6.noarch.rpm from zabbix: [Errno 256] No more mirrors to try.
Is this ok [y/N]: y
yum clear all
yum update
