Because the speed of these radio outdoor interfaces is 0 Mbps?
  • Filter
    This is the monitoring of the outdoor radio Ubiquiti PowerBeam M5-300. I applied to the host the template 'Template Net Ubiquiti AirOS SNMPv1', and it came with some prototype items. The ath0 (atheros - wifi), br0 (bridge), eth0 (ethernet) and wifi0 interfaces were discovered. Interface item prototype ath0: Interface type informs that for all interfaces the same value is 'ethernetCsmacd (6)'. However, Speed ​​reports that only eth0 has 100mbps, while ath0, br0, wifi0 always registers 0Mbps. The item key is 'net.if.speed [ifSpeed. {# SNMPINDEX}]'. Why is this value 0 Mbps? And would it really be useful for me to monitor these four interfaces? If so, when?
    Could it be that those interfaces are disabled/not used ? Talk to your engineer/supplier/vendor. To answer your second question do the same. Nothing really to do with zabbix - to monitor properly your device you need to know a bit about it ...documentation of the device, somebody whos is responsible for it, your vendor....if its you than you have to find out on your own
    Announcement
    No announcement yet.
