Using PHP Network WeatherMap with Zabbix
  • Tungsten
    • Jun 2008
    I just start to use Zabbix few weeks ago and I'm really impressed by the product philosophy and possibilities...
    I'm an old nagios user and several things I actually use with nagios or cacti are missing.
    First one was Network Weather Map (www.network-weathermap.com) integration.
    So I made a datasource plugins in order to retrieve item value from zabbix history and use it in network weather map :
    The Target syntax is : zabbix:itemid_of_IN_value:temid_of_OUT_value
    You need to write down the itemid of each item you want to integrate with. A little bit anoying, but that's working !
    Also The plugin use only History_uint table for retreiving data.
    /weathermap/lib/datasources/WeatherMapDataSource_zabbix.php
    <?php
    // Zabbix Pluggable datasource for PHP Weathermap 0.9
    // - read a pair of values from a database, and return it
    // Actually the plugin look only in history_uint table
    // TARGET zabbix:in:out
    class WeatherMapDataSource_zabbix extends WeatherMapDataSource {
            function Init(&$map)
                    if(! function_exists("mysql_real_escape_string") ) return FALSE;
                    if(! function_exists("mysql_connect") ) return FALSE;
                    return(TRUE);
            function Recognise($targetstring)
             if(preg_match("/^zabbix:([\-a-zA-Z0-9_]+):([\-a-zA-Z0-9_]+)$/",$targetstring,$matches))
                            return TRUE;
                    else
                            return FALSE;
            function ReadData($targetstring, &$map, &$item)
                    $data[IN] = NULL;
                    $data[OUT] = NULL;
                    $data_time = 0;
                            $database_user = $map->get_hint('zabbix_dbuser');
                            $database_pass = $map->get_hint('zabbix_dbpass');
                            $database_name = $map->get_hint('zabbix_dbname');
                            $database_host = $map->get_hint('zabbix_dbhost');
                            $raw_in = mysql_real_escape_string($matches[1]);
                            $raw_out= mysql_real_escape_string($matches[2]);
                            debug ("Found for IN Value :  $raw_in \n");
                            debug ("Found for OUT Value :  $raw_out \n");
                            $SQL_IN = "select value from history_uint where itemid=$raw_in order by clock desc limit 1";
                            $SQL_OUT = "select value,clock from history_uint where itemid=$raw_out order by clock desc limit 1";
                            if(mysql_connect($database_host,$database_user,$database_pass))
                                    if(mysql_select_db($database_name))
                                            $result_IN = mysql_query($SQL_IN);
                                            if (!$result_IN)
                                                warn("Zabbix ReadData: Invalid query for IN Value: " . mysql_error()."\n");
                                            else
                                                    $row_IN = mysql_fetch_assoc($result_IN);
                                                    $data[IN] = $row_IN['value'];
                                            $result_OUT = mysql_query($SQL_OUT);
                                            if (!$result_OUT)
                                                warn("Zabbix ReadData: Invalid query for OUT Value: " . mysql_error()."\n");
                                            else
                                                    $row_OUT = mysql_fetch_assoc($result_OUT);
                                                    $data[OUT] = $row_OUT['value'];
                                                    $data_time = $row_OUT['clock'];
                                    else
                                            warn("Zabbix ReadData: failed to select database ($database_name): ".mysql_error()."\n");
                            else
                                    warn("Zabbix ReadData: failed to connect to database server: ".mysql_error()."\n");
                    //      $data_time = now();
                    debug ("RRD ReadData: Returning (".($data[IN]===NULL?'NULL':$data[IN]).",".($data[OUT]===NULL?'NULL':$data[IN]).",$data_time)\n");
                    return( array($data[IN], $data[OUT], $data_time) );
  • bbrendon
    • Sep 2005
    • 870
    Looks interesting. Can you post some screen shots?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Tungsten
      • Jun 2008
      Here a small screenshot (French Translated)
      Actually it's part of an zabbix screen...
      Bandwith Update occurs every 60s.
      • pcamelio
        • Jul 2005
        • 67
        Hi tungsten
        Can you explain deeper how you make weathermap working with zabbix , I am really interested in
        I download it, but I still confused how it is working with zabbix
        • pierre-hoffmann
          • Jan 2008
          • 133
          I'm also interessting to use it,
          But where you say what data you want to "Graph" ??
          Regards,
          Pierre (From France :-)
          P.Hoffmann
          System & Network Admin.
          __________________________
          Zabbix version 1.8.1
          Hosts monitored 1300
          OS Novell SLES 10 SP2
          • Tungsten
            • Jun 2008
            Ok I will try to write a complete tutorial for that ...
            Regards,
            Tungsten (From France)
            • bee
              • Jun 2007
              • 133
              Interesting post!
              What version of ZABBIX you running on?
              Cheers,
              BEE
              • Tungsten
                • Jun 2008
                I'm using the 1.45 Version on a Jeos Appliance.
                • Howie
                  • Jun 2008
                  Hi, I write Network Weathermap... at some point in the next couple of versions there will be new functions for data source plugins so that they can supply lists of possible data sources to the editor. At that stage, you should be able to pick interfaces/whatever from Zabbix in the editor, and it will do the right thing to fill in the target, infourl etc.
                  Thanks Tungsten for extending Weathermap's reach, too
                  • theologu
                    • Dec 2007
                    • 23
                    Tungsten, many thanks for telling us about Network WeatherMap...and for making that data-source for zabbix, it is a really good thing to complete Zabbix maps.
                    Howie, I am glad that you joined Zabbix forum, and congrats for writing Network WeatherMap; I didn`t tryed to install it yet, but I will sure do; Extending functionalities of your software to co-operate with zabbix which has a big user base will be a great thing for both "sides"
                    • theologu
                      • Dec 2007
                      • 23
                      Tungsten, you said that your scrrenshot is part of a zabbix screen... how did you integrated the map generated by NWM into a zabbix screen?
                      • dminstrel
                        • Apr 2005
                        • 72
                        I've started playing around with it and after some tinkering, I have a working weathermap. This adds an excellent visualization tool to ZABBIX, especially for complex networks.
                        A very quick HOWTO:
                        1) Install php-weathermap somewhere.
                        2) Read the fine manual
                        3) Create a weathermap of the hosts you want to monitor.
                        4) Configure WeatherMapDataSource_zabbix.php (and put it in the right place at weathermap/lib/datasources - not in the ZABBIX directory).
                        5) To get the id's of the Items to put in the map, I've named all my traffic Items "Traffic..." so I ran the following MySQL query:
                        SELECT * FROM items i where description LIKE 'Traffic%';
                        this gets me the itemid I need to put into the weathermap configuration file. Note that I got error messages around lines 44 and 45 of the php file because my root MySQL user has a password. I guess these are for debugging purposes. I've also hardcoded the host, username and password of the database at around line 52 and hardcoded the datbase name at line 54. The variables didn't seem to work. Also note that the Items must be Integers or the script won't work.
                        6) Create the weathermap using "php ./weathermap --config mymap.conf"
                        7) Enjoy
                        8) If you want your map to auto-update itself, create a cron job or a Windows Scheduled Task to run the command at step 6)
                        • pcamelio
                          • Jul 2005
                          • 67
                          Quickly the SQL syntax to get itemid with the hostname and the description field to make the itemid search easier
                          SELECT hosts.host, items.description, items.itemid
                          FROM items, hosts WHERE items.hostid = hosts.hostid AND hosts.host LIKE '%PATTERN%'
                          Hope this help for people who are not easy with mysql
                          • rreilly
                            • May 2007
                            • 61
                            mouse over graphs ?
                            I have used PHP weather map before and really like the fucntionality of mouse over java script (libover ?) with rrd and the pop up graphs. has anyone thought about this or started working on it for zabbix ?
                            • alucard95
                              • Sep 2008
                              • 38
                              #15
                              Hi all!
                              I've some difficulty to integrate network weathermap in zabbix, i find the itemid but i don't know how use it in network weathermap.
                              Anybody can help me or have a tutorial please?
