Using PHP Network WeatherMap with Zabbix
  • fireless
    • Oct 2015
    Help
    I'm newbie on Zabbix and I would like add php weathermap on my Zabbix.
    It's possible to have a tutorial to install and configure it ? And how to create a weather map ?
    I already tried with the information on this post, but I don't understand all.
    Thanks for your help !
    My Zabbix 2.4.6
    • stav13
      • Oct 2013
      • 66
      #47
      My Zabbix 2.4.6
      Sure, I have just finished implementing weathermap and have it all working now though I haven't tried getting the graphs to work yet ....
      Give me a few days and ill update this tread with all of the details.
      Cheers
      • fireless
        • Oct 2015
        Cheers
        Hi stav13 !
        Thank you !!
        • AlexYoung
          • Jul 2013
          • 37
          #49
          That would be brilliant as i want to implement it at some point
          • stav13
            • Oct 2013
            • 66
            #50
            Hi All,
            Sorry but have been very busy at work so have quickly wrote this up in my short lunch break.
            Install Weathermap
            Move zab_chart.php to default location of Zabbix web front end.
            Move both files to /weathermap/lib/datasources;
            WeatherMapDataSource_zabbixitem.php
            WeatherMapDataSource_zabbixhost.php
            In both files there is a line as below, enter a username and password for zabbix
            $useropt=array(user => 'ENTER USERNAME','password'=>'ENTER PASSWORD');
            Move both below files into the /weathermap/configs;
            test.conf
            zab_template.conf
            in zab_template.conf amend the URL to your zabbix URL
            OVERLIBGRAPH http://URL/zabbix/weathermap_chart.php?host[]={link:this:hostname_in}&item[]={link:this:itemkey_in}&host[]={link:this:hostname_out}&item[]={link:this:itemkey_out}&color[]=009900&color[]=000099&drawtype[]=5&drawtype[]=2&height=150&width=600&legend=1&period=43200
            INFOURL http://URL/zabbix/weathermap_chart.php?host[]={link:this:hostname_in}&item[]={link:this:itemkey_in}&host[]={link:this:hostname_out}&item[]={link:this:itemkey_out}&color[]=009900&color[]=000099&drawtype[]=5&drawtype[]=2&period=86400
            Create two png files called icon_up.png and icon_down.png representing that status and move to /weathermap/images
            Comment out line 94 in file CLocalApiClient.php located in /var/www/html/zabbix/include/classes/api/clients/
            Before;
            unset($params['nopermissions']);
            After;
            // unset($params['nopermissions']);
            I might have missed something but please have a go and if you get issues let me know and ill try my best to help!!!!
            Last edited by stav13; 17-02-2016, 11:18. Reason: CLocalApiClient.php change, thanks to Jason for pointing this out!!
            • huangyingja
              • Apr 2015
              • 27
              #51
              Thank you bros, it's really helpful to me !
              I want try to use it to integrate with cacti ~
              • Jason
                • Nov 2007
                • 431
                #52
                Has anyone got this working with zabbix 2.4.X?
                I'm using the amousset plugin and information by stav to get up and running, but I'm getting the error below.
                PHP Fatal error: Cannot unset string offsets in /var/www/html/zabbix/include/classes/api/clients/CLocalApiClient.php on line 94
                • stav13
                  • Oct 2013
                  • 66
                  #53
                  Hi Jason
                  Do you get this error when trying to build a map? Can you please attach a copy of the map config and the php file and I'll have a look when I can.
                  • Jason
                    • Nov 2007
                    • 431
                    #54
                    I commented out the following line in the file and it all seems to work fine although that might cause other issues.
                    // the nopermission parameter must not be available for external API calls.
                    # unset($params['nopermissions']);
                    I'm running 2.4.7 btw on 64bit Centos 6. My test map (only 2 nodes currently) seems to build ok...
                    Has no-one written a parser to convert a map export from zabbix to the basic format for weathermap?
                    • stav13
                      • Oct 2013
                      • 66
                      #55
                      Sorry Jason, my bad! that line is commented out on my system as well.
                      Must have done it whilst I was installing the app and forgot!
                      Has anyone made the leap to Zabbix 3.0 and tested weathermap with it yet ??
                      • stav13
                        • Oct 2013
                        • 66
                        #56
                        Hi All,
                        FYI - I can confirm this is working for Zabbix 3.0.1
                        • colloque
                          • Feb 2010
                          • 72
                          #57
                          I am sorry but i have a problem with the command
                          weathermap.py (I am using zabbix 3.0.1)
                          I have the following error:
                          command:
                          ./weathermap.py -s test_map -z http://x.x.x.x -l Admin -p xxxx
                          Error:
                          Traceback (most recent call last):
                          File "./weathermap.py", line 123, in <module>
                          main()
                          File "./weathermap.py", line 120, in main
                          WeathermapCLI()
                          File "./weathermap.py", line 55, in __init__
                          self._map_scan()
                          File "./weathermap.py", line 67, in _map_scan
                          map_data = zbx.scan_map(map_n)
                          File "/opt/Zabbix-Network-Weathermap/zabbix.py", line 76, in scan_map
                          raise ZbxException('map: {} not found'.format(map_name))
                          zabbix.ZbxException: map: test_map not found
                          Do you have an idea?
                          Thanks in advance.
                          Best Regards
                          • stav13
                            • Oct 2013
                            • 66
                            #58
                            command:
                            Error:
                            main()
                            WeathermapCLI()
                            self._map_scan()
                            Thanks in advance.
                            Best Regards
                            Sorry but I don't run that command to generate my maps. To be honest I'm not sure what that command does. What are you trying to achieve?
                            • colloque
                              • Feb 2010
                              • 72
                              #59
                              Thanks for your reply.
                              I saw it on the website in the readme.md part in the script section:
                              Network weathermap for Zabbix. Contribute to Prototype-X/Zabbix-Network-Weathermap development by creating an account on GitHub.
                              Thanks.
                              • dampersand
                                • Apr 2016
                                • 16
                                #60
                                Hey,
                                So first off, you folks are gentlemen/women and scholars, the lot of you. This thread is chock-full of useful information (if a bit spread out).
                                Second - I'm running this using stav13's tutorial-ish-thingy on Zabbix 3.0.1 and weathermap v0.97c.
                                I have run into an error that is an easy fix, and wanted to assist:
                                PHP Fatal error:  Call to undefined function warn() in /usr/share/zabbix/weathermap/lib/datasources/WeatherMapDataSource_zabbixhost.php on line 47
                                Can be solved by editing line 47 the file in question (WeatherMapDataSource_zabbixhost.php) to read
                                if(empty($item_)) wm_warn("ZabbixItem ReadData: Not found item for host '$host_name' and key_ '$item_key'");
                                Instead of
                                if(empty($item_)) warn("ZabbixItem ReadData: Not found item for host '$host_name' and key_ '$item_key'");
                                You should also edit WeatherMapDataSource_zabbixitem.php for the same reason. warn() is not used in this version of weathermap, now it's wm_warn().
                                By the way... there have been some changes, it seems, in the way this stuff works. Would someone who has used stav13's tutorial implemented with zabbix be willing to post a test config? The test configs in this thread are often missing various lines like "SET zabbix_user <username>" and stuff, so I'm not 100% on what has changed, what's required, etc. I've been trial-and-erroring the crap out of it, but if someone has a dead-on working test config, I would be super grateful!
