Cisco edge device templates
  • troffasky
    • Jul 2008
    • 628
    I've created a template for monitoring Cisco ASA firewalls. This one has been tested on a 5505 running ASA Version 8.0(2) and a 5510 running 7.2 firmware. It contains OIDs and some graphs for connections, IKE/IPSEC sessions/users/throughput, 1min CPU load and memory usage, plus the standard 24 ethernet interfaces. There are no triggers currently defined. Some of the OIDs also work for Cisco ISRs [877, 1841, etc].
  • troffasky
    • Jul 2008
    • 628
    Cisco router + DSL stat templates
    Attached is a Cisco router template with the usual interfaces, Cisco CPU usage and global IPSEC/IKE throughput. Also attached is a Zip file containing 24 templates for DSL interfaces stats and DSL up/down sync speeds, plus one unzipped so you can see it without downloading the zip. The reason for the 24 separate templates is that the index number of a DSL interface varies from one router to the next.
    If you walk the CISCO-IPSEC-FLOW-MONITOR-MIB of your Cisco device, you'll be able to see the indices of the individual IPSEC tunnels, so if you're interested in throughput on a specific tunnel [rather than global IPSEC throughput] then you can monitor the cipSecTunHcIn/OutOctets.n values, where 'n' is the index of that particular tunnel.
    Instructions
    1. Upload the Template_Cisco_Router.xml
    2. Create a device and link it to Template_Cisco_Router
    3. Navigate to Monitoring > Latest Data, scroll down to find an interface called ATM0-asdl or similar on the device you've just created and look at the index number. On the 877 for example, it might be ifDescr11 has a value of ATM0-adsl, thus the index number for that interface is '11'.
    4. From the zip file, upload the corresponding template, in this case Template_Cisco_DSL_int.11.xml
    5. Link this template to your device. Your new device will now have two templates linked to it.
    6. Sit back and watch the DSL line stats roll in. Eventually, you will see a graph like this:
    • troffasky
      • Jul 2008
      • 628
      I've noticed on a few routers that the DSL stats go a bit haywire when the line drops, specifically I've seen the downstream noise margin figure can go up to 320,000 tenths of a dB. I suppose the only positive side effect of this is that you can see on your graphs when the line has dropped!
      • mattboston
        • Feb 2010
        I tried to use this template and it doesn't seem to work. Do you have an updated template that works with an ASA Version 8.2(1)?
        thanks
        -matt
        • troffasky
          • Jul 2008
          • 628
          I don't have anything with 8.2 to test with I'm afraid, and to be honest I don't use this template any more as using one of the template generators is easier. I do still use the DSL interface stats templates.
          What items don't work with 8.2? If the answer is 'all of them', then I suspect something more fundamental is at play.
          • THUHV
            • Dec 2009
            • 28
            Hi bro, may i use cisco router template to monitor Cisco router 2811/2800 right?
            plz reply to let me know, thanks you!
            • troffasky
              • Jul 2008
              • 628
              You can try, but if [or rather, because] the interface indices are different, the output will be meaningless.
              Like I said to mattboston, just use a template generator.
              • Missing
                • Jan 2011
                i have a question , maybe the template has a problem about bankwidth , i'm running zabbix 1.8.3 ,import this template for a cisco asa 5510 ,then create a host named 5110,but every interface show bandwidth is not right , example if interface.9 bandwidth is 800K,but the graphs is 100K ,the right value is the zabbix get value * 8 . it seems somewhere has a calcution error.
                • pt_tomcat
                  • Mar 2012
                  I tried to import on zabbix 1.8.5. seems doesn't work on that version.
                  is there any update for that database?
                  Cheers
                  Arash
                  • dav1dc
                    • Mar 2012
                    I had the same problem...
                    I suspect that this is one of those templates that was exported with special characters that could not be re-imported. #fail
                    I noticed that colons ( : ) are special characters in the Zabbix key notation - so I removed the double colon ( :: ) from the key name and VoilĂ  the Cisco ASA template was successfully imported into Zabbix FrontEnd v1.8.10!
                    I have attached the cleansed version for your convenience!
                    ^_^
                    Cheers,
                    -D.
                    • pt_tomcat
                      • Mar 2012
                      Thank you indeed.
                      it worked.
                      • eskytthe
                        • May 2011
                        • 363
                        Fine basis template for asa, but I am looking for one with more features like:
                        - triggers
                        - in and output errors on interfaces
                        - drop packet count
                        - more vpn statistic
                        (- LLD for zabbix ver. 2.x?)
                        ... more
                        Anyone who would like to upload their extended cisco asa template?
                        (... else I will have to make it my self )
                        BR
                        Erik
                        • hrickh
                          • May 2015
                          • 10
                          - triggers
                          - drop packet count
                          ... more
                          BR
                          Erik
                          have you made one already?
                          or did you find any?
                          can you please share
