Orabbix:"Another way to monitor Oracle reloaded"
  • sistemas.aquanima
    • Oct 2013
    All my monitoring problems solved using Zabora, damn I thought using Orabbix was the solution.
    • euska
      • Oct 2013
      #407
      I would like to get the free space in % .
      Can anyone help me on this query ?
      • euska
        • Oct 2013
        #408
        Got it using :
        SELECT ROUND(SUM(bytes/1024/1024) / (SELECT SUM(bytes/1024/1024) FROM dba_data_files)*100,2) FROM dba_free_space GROUP BY 1;
        • cincin
          • Jan 2014
          Orabbix - nodata graph
          Hello
          We have an orabbix (1.2.3) on a zabbix (2.2.1).
          From the orabbix logs everything seems to be ok:
          2014-01-14 15:56:03,510 [pool-1-thread-39] DEBUG Orabbix - Actual query is sessionNextrun 2014/01/14 15:55:35 on database=XXXX Period=2
          2014-01-14 15:56:03,511 [pool-1-thread-39] DEBUG Orabbix - I'm going to return 89 for query session on database=XXXX
          2014-01-14 15:56:03,512 [pool-1-thread-39] DEBUG Orabbix - Actual query is session_systemNextrun 2014/01/14 15:55:35 on database=XXXX Period=2
          2014-01-14 15:56:03,513 [pool-1-thread-39] DEBUG Orabbix - I'm going to return 21 for query session_system on database=XXXX
          2014-01-14 15:56:03,513 [pool-1-thread-39] DEBUG Orabbix - Actual query is sga_buffer_cacheNextrun 2014/01/14 15:55:35 on database=XXXX Period=2
          2014-01-14 15:56:03,518 [pool-1-thread-39] DEBUG Orabbix - I'm going to return 1024 for query sga_buffer_cache on database=XXXX
          2014-01-14 15:56:03,518 [pool-1-thread-39] DEBUG Orabbix - Actual query is sga_fixedNextrun 2014/01/14 15:55:35 on database=XXXX Period=2
          2014-01-14 15:56:03,523 [pool-1-thread-39] DEBUG Orabbix - I'm going to return 2.12 for query sga_fixed on database=XXXX
          But we don't have data on "Latest data".
          Also on orabbix logs we have:
          2014-01-14 15:56:04,195 [pool-1-thread-39] DEBUG Orabbix - sending <req><host>anVsaWFkYg==</host><key>cG9vbF9kaWN0X2NhY2hl</key><data>MA==</data></req>
          2014-01-14 15:56:04,196 [pool-1-thread-39] DEBUG Orabbix - sending <req><host>anVsaWFkYg==</host><key>c3FsUmVzcG9uc2U=</key><data>MS41NA==</data></req>
          2014-01-14 15:56:04,196 [pool-1-thread-39] DEBUG Orabbix - sending <req><host>anVsaWFkYg==</host><key>cG9vbF9mcmVlX21lbQ==</key><data>MjI0LjI3</data></req>
          2014-01-14 15:56:04,196 [pool-1-thread-39] DEBUG Orabbix - sending <req><host>anVsaWFkYg==</host><key>cG9vbF9saWJfY2FjaGU=</key><data>MA==</data></req>
          Thank you
          • dalle
            • Mar 2009
            • 402
            #410
            Originally posted by cincin
            Hello
            Thank you
            This mean that Orabbix is sending data to zabbix, are you sure you have the same host name you defined for orabbix in Zabbix too?
            Andrea Dalle Vacche
            website:http://www.smartmarmot.com/
            e-mail:
            Author of:Mastering Zabbix Book - second edition
            Zabbix Network Monitoring Essentials
            • dalle
              • Mar 2009
              • 402
              #411
              Win Free Ecopy of new book on Zabbix!
              Readers would be pleased to know that I have teamed up with Packt Publishing to organize a Giveaway of the Mastering Zabbix
              And three lucky winners stand a chance to win ecopy of their new book. Keep reading to find out how you can be one of the Lucky Winners.
              More information are available here
              Andrea Dalle Vacche
              e-mail:
              • GemTTb
                • Sep 2013
                • 14
                #412
                Hello Dalle and team and thank you very much for this solution.
                It took me several days to have orabbix working but I'm still having trouble with it and couldn't resolve it so far.
                Let me sum up the the environment and all my action
                Env: Zabbix appliance on suse provided by zabbix site having jre6u45, Oracle 10g installed on Win XP with hostname MACHINE_ORACLE
                Actions:
                1) Downloaded and installed orabbix on my zabbix server machine.
                2) Configured orabbix using config.props as below
                ZabbixServerList=ZabbixServer1
                ZabbixServer1.Address=10.10.1.230
                ZabbixServer1.Port=10051
                OrabbixDaemon.PidFile=./logs/orabbix.pid
                OrabbixDaemon.Sleep=300
                OrabbixDaemon.MaxThreadNumber=100
                DatabaseList=DB1
                DatabaseList.MaxActive=10
                DatabaseList.MaxWait=100
                DatabaseList.MaxIdle=1
                DB1.Url=jdbcracle:thin:@10.10.1.6:1521:pcep
                DB1.User=test
                DB1.Password=test
                DB1.MaxActive=10
                DB1.MaxWait=100
                DB1.MaxIdle=1
                DB1.QueryListFile=./conf/query.props
                3) imported the template Template_Oracle provided by orabbix distribution.
                4) Created a host on zabbix named pcep and add to this host the Template_Oracle just added.
                5) Started the Zabbix_agent on the MACHINE_ORACLE successfully and getting some data like Memory_utilization data.
                6) started the orabbix daemon successfully.
                7) Changed the log level on the orabbix and getting :
                2014-02-18 11:08:57,559 [main] DEBUG Orabbix - Waking up Goood Morning
                2014-02-18 11:08:57,560 [main] DEBUG Orabbix - Loaded the properties from ./conf/query.props
                2014-02-18 11:08:57,561 [main] DEBUG Orabbix - Note: archive.NoDataFound null or not present null
                2014-02-18 11:08:57,562 [main] DEBUG Orabbix - Note: archive.WhenNotAlive null or not present null
                2014-02-18 11:08:57,562 [main] DEBUG Orabbix - Note: archive.Period null or not present null
                2014-02-18 11:08:57,562 [main] DEBUG Orabbix - Note: archive.ExcludeColumnsList error null
                8) On the zabbix GUI I couldn't get any data on the graphs.
                Was something missing or wrong during configuration? I'm struggling with this, so please help.
                Last edited by GemTTb; 18-02-2014, 16:24. Reason: Zabbix not getting data from Orabix
                • sybex
                  • Aug 2008
                  • 29
                  #413
                  Hi, ...
                  orabbix has to know the servername from the server in zabbix, in your example config the servername would be "DB1"
                  Change this value to match the data to your host.
                  e.g. Server in Zabbix: testserver01
                  testserver01.Url=jdbcracle:thin:@10.10.1.6:1521cep
                  testserver01.User=test
                  testserver01.Password=test
                  A lot of the orabbix config is optional. Check the Docs.
                  • GemTTb
                    • Sep 2013
                    • 14
                    #414
                    Thank you Sybex for your quick reply.
                    That was it, I had to use the "DB1" as the hostname on zabbix server host name and I finally started to get data.
                    That's somehow wierd, because on the Orabbix documentation page, the name has to be the SID.
                    HTML Code:
                    ensure the name of your host in Zabbix is the same name of the SID or Oracle instance name.
                    Anyways it's working, so it's fine by now.
                    Thank you very much :-)
                    • cincin
                      • Jan 2014
                      Hello Dale
                      Thaks for your response.
                      That was the problem, the host name wasn´t the same with the name of DB in orabbix.
                      Now is working fine.
                      I have one more question: how can we set the check period of the query.props file?
                      Thank you
                      • s4chin
                        • Mar 2014
                        #416
                        No data on zabbix server
                        Hi Frnds,
                        I have zabbix server on 192.168.0.162 (CentOS 6.5). Zabbix version is 2.2.1.
                        My Oracle server (10.2.0.5) is on 192.168.0.244. So i installed orabbix 1.2.3 on oracle server in /opt directory and i think it is working ok. I imported oracle template "Orabbix_export_full.xml" from orabbix template folder in zabbix server and added host also...but there is no data on zabbix server related to oracle template
                        My files config are :
                        1 ) config.props
                        ZabbixServer1.Address=192.168.0.162
                        OrabbixDaemon.MaxThreadNumber=2
                        DatabaseList=DB1
                        DB1.Url=jdbcracle:thin:@192.168.0.244:1521rcltest10g
                        DB1.User=zabbix
                        DB1.Password=zabbix
                        DB1.MaxActive=10
                        DB1.MaxWait=100
                        DB1.MaxIdle=1
                        2) orabbix.log
                        2014-03-08 10:23:57,935 [main] INFO Orabbix - Starting Orabbix Version 1.2.3
                        2014-03-08 10:23:57,989 [main] INFO Orabbix - Orabbix started with pid:5099
                        2014-03-08 10:23:57,989 [main] INFO Orabbix - PidFile -> ./logs/orabbix.pid
                        2014-03-08 10:23:58,434 [main] INFO Orabbix - DB Pool created: org.apache.commons.dbcp.datasources.SharedPoolData Source@7a3f437c
                        2014-03-08 10:23:58,434 [main] INFO Orabbix - URL=jdbcracle:thin:@192.168.0.244:1521rcltest10g
                        2014-03-08 10:23:58,434 [main] INFO Orabbix - maxPoolSize=10
                        2014-03-08 10:23:58,435 [main] INFO Orabbix - maxIdleSize=1
                        2014-03-08 10:23:58,435 [main] INFO Orabbix - maxIdleTime=1800000ms
                        2014-03-08 10:23:58,435 [main] INFO Orabbix - poolTimeout=100
                        2014-03-08 10:23:58,435 [main] INFO Orabbix - timeBetweenEvictionRunsMillis=-1
                        2014-03-08 10:23:58,435 [main] INFO Orabbix - numTestsPerEvictionRun=3
                        2014-03-08 10:24:02,369 [main] INFO Orabbix - Connected as ZABBIX
                        2014-03-08 10:24:02,376 [main] INFO Orabbix - --------- on Database -> orcltest
                        2014-03-08 10:24:04,576 [pool-1-thread-1] INFO Orabbix - Done with dbJob on database DB1 QueryList elapsed time 1988 ms
                        2014-03-08 10:25:02,665 [pool-1-thread-2] INFO Orabbix - Done with dbJob on database DB1 QueryList elapsed time 31 ms
                        Why there is no data on zabbix server
                        • Vapochilled
                          • Nov 2013
                          • 17
                          #417
                          Hi, is DB1 the hostname of that hostname in zabbix server?
                          It needs to be the same
                          • s4chin
                            • Mar 2014
                            #418
                            no its not
                            DB1 is name of the variable
                            DatabaseList=DB1
                            ok let me put Hostname instead of DB1
                            • tirorex
                              • May 2014
                              Hello. Is it possible to send a parameter to query.
                              For example
                              tablespace_space_used.Query[{#TS_NAME}]="select sum() from ... where tablespace name='$1'"
                              • Alexander Podkopaev
                                • Mar 2014
                                ExtraQueryListFile is not clear for me
                                Originally posted by dalle
                                the following parameter
                                <DB_NAME>.ExtraQueryListFile =
                                add another custom query to a default query file.
                                if there are duplicate the ExtraQueryListFile will override them.
                                Using this feature is not clear for me:
                                1. if I put QueryList parameter in 'extra' file - will it override QueryList from 'base' props or will merge them?
                                2. Is it possible to have more than one ExtraQueryListFile?
                                My usecase for ExtraQueryListFile is separating scripts to two or more scripts with different modification rights:
                                1. base monitoring scripts - writeable by senior DBA only
                                2. instance or solution -depended scripts - writeable by principal DBAs
