IPMI Template For IBM Integrated Management Module
  • sire
    • Jul 2010
    • 210
    I have made a template for monitoring IBM servers supplied with Integrated Management Module (IMM) via IPMI protocol. It has data elements and graphs for fan speeds, power consumption and ambient temperature. Tested on IBM System x 3550 servers.
    Regards,
    Sergey Syreskin
    Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
    Temporary out of Zabbix business
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Moved to Zabbix Cookbook.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • djack
      • Jun 2010
      Configuration station in Zabbix for IMM Monitoring
      Could you write more information about configuration host in Zabbix for IMM monitoring.
      DJack
      • sire
        • Jul 2010
        • 210
        DJack
        What information do you mean?
        Regards,
        Sergey Syreskin
        • djack
          • Jun 2010
          IPMI for IBM
          I have a zabbix server on IBM x3250 and I can connect to IMM on it through http://address (user: admin, password: pass).
          I have created host on zabbix, set use IPMI and defined parameters:
          IPMI IP address: address
          IPMI port: 623
          IPMI authentication algorithm: default
          IPMI privilege level: Admin
          IPMI username: admin
          IPMI password: pass
          But I can not get information from IMM.
          What parameters I have to correctly set on host in zabbix and on IMM IBM server?
          DJack
          • sire
            • Jul 2010
            • 210
            IPMI port: 623
            IPMI password: pass
            DJack
            I use the same settings on my x3550 except username and password and it works.
            Regards,
            Sergey Syreskin
            • djack
              • Jun 2010
              Did you set some parameters on IBM server (like TCP port)?
              Because on my IMM server I can see in "Port Assignments" message:
              "Currently, the following ports are open on this IMM:
              22, 23, 80, 161, 162, 443, 3900, 5988, 6012
              I can not see that port 623 is open.
              DJack
              • sire
                • Jul 2010
                • 210
                No I didn't. Everything worked out of the box. Did you enter the same username and password as in the IMM web page? Default IMM username and password differ from those you specified. They are USERID and PASSW0RD with zero instead of capital letter O in the password.
                Regards,
                Sergey Syreskin
                • ruswold
                  • Mar 2010
                  • 210
                  DJack
                  Set StartIPMIPollers=1 at zabbix_server.conf
                  By default set = 0.
                  • rjyang
                    • Dec 2008
                    It don't work on x3650 M3
                    I think x3650 M3 IMM not support IPMI, I can't find the location of IPMI configuration on the IMM console, and the port 623 is not available.
                    • sire
                      • Jul 2010
                      • 210
                      Here is a new template for IBM System x3550 with more parameters. It is generated with the help of scripts published here http://www.tune-it.ru/web/tiamat/home/-/blogs/17465. I didn't test the template because I currently have no access to the management module from my Zabbix machine.
                      Regards,
                      Sergey Syreskin
                      • vzanchettin
                        • Jul 2011
                        It works!
                        Your template it´s very good!
                        Thanks a lot.
                        • sire
                          • Jul 2010
                          • 210
                          I have noticed that analog IPMI sensors are not supported by Zabbix, so it is better to disable or remove them from the template.
                          Regards,
                          Sergey Syreskin
                          • efcunha
                            • Apr 2012
                            as you did the configuration of the IMM for the x3350 zabbix could read like an IPMI ?
                            • sire
                              • Jul 2010
                              • 210
                              #15
                              If I understand your question correct, IBM IMM module in x3550 supports IPMI and Zabbix can read IPMI data from it.
                              Regards,
                              Sergey Syreskin
