IPMI Template For IBM Integrated Management Module
  • Andre Torres
    • Jun 2012
    Where did you find them?
    Sire,
    First of all, I'd like to thank you for the templates. I'm testing them just now.
    I was wondering where you got those item keys and sensors. Is there any documentation for this?
    I'd like to also monitor disk's health, so guess I need to know their keys, but I don't know how.
    Thank you in advance.
    Andre Torres
    • sire
      • Jul 2010
      • 210
      #17
      Hi Andre,
      The template was generated with the help of the scripts published here.
      IBM IMM IPMI board doesn't know anything about disk health, as far as I know. You need to install Zabbix agent inside the host OS and use smartctl or something else to get these data. See Zabbix docs on UserParameter.
      Regards,
      Sergey Syreskin
      Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
      Temporary out of Zabbix business
      • Andre Torres
        • Jun 2012
        Originally posted by sire
        Hi Andre,
        Hello again Sergey.
        I'm running VMware ESXi 5.0 on my server, that's why I can't use the agent to get info about disk health.
        I runned this command on my Zabbix Server:
        ipmitool -H SERVER_IMM_IP -U USER -P PASSWORD sdr
        If I understood it right, this command gives me the sensors I need to monitor. Here is the result:
        Planar 3.3V      | 3.32 Volts        | ok
        Planar 5V        | 5.04 Volts        | ok
        Planar 12V       | 11.99 Volts       | ok
        Planar 5V SB     | 5.02 Volts        | ok
        CPU 1 VCore      | 1.07 Volts        | ok
        CPU 2 VCore      | disabled          | ns
        Planar VBAT      | 3.09 Volts        | ok
        CPU 1 VDIMM      | 1.50 Volts        | ok
        CPU 2 VDIMM      | disabled          | ns
        IOH 1.1V         | 1.10 Volts        | ok
        Avg Power        | 200 Watts         | ok
        Ambient Temp     | 24 degrees C      | ok
        IMM Temp         | 51.20 degrees C   | ok
        Fan 1 Tach       | 1750 RPM          | ok
        Fan 2 Tach       | 1750 RPM          | ok
        Fan 3 Tach       | 1750 RPM          | ok
        Host Power       | 0x00              | ok
        IPMI Watchdog    | 0x00              | ok
        Power 12V Fault  | 0x01              | ok
        VRD              | 0x00              | ok
        VRM              | Not Readable      | ns
        Pwr Rail A Fault | 0x01              | ok
        Pwr Rail B Fault | 0x01              | ok
        Pwr Rail C Fault | 0x01              | ok
        Pwr Rail D Fault | 0x01              | ok
        Pwr Rail E Fault | 0x01              | ok
        Pwr Rail F Fault | 0x01              | ok
        IOH Temp Status  | 0x01              | ok
        All DIMMS        | 0x00              | ok
        One of the DIMMs | 0x00              | ok
        Backup Memory    | 0x00              | ok
        OS RealTime Mod  | 0x00              | ok
        Fan 1            | 0x01              | ok
        Fan 2            | 0x01              | ok
        Fan 3            | 0x01              | ok
        Cooling Zone 1   | 0x01              | ok
        Cooling Zone 2   | 0x01              | ok
        Cooling Zone 3   | 0x01              | ok
        Drive 0          | 0x01              | ok
        Drive 1          | 0x01              | ok
        Drive 2          | 0x01              | ok
        Drive 3          | 0x01              | ok
        Drive 4          | 0x01              | ok
        Drive 5          | 0x01              | ok
        Drive 6          | 0x00              | ok
        Drive 7          | 0x00              | ok
        Drive 8          | 0x00              | ok
        Drive 9          | 0x00              | ok
        Drive 10         | 0x00              | ok
        Drive 11         | 0x00              | ok
        Drive 12         | 0x00              | ok
        Drive 13         | 0x00              | ok
        Drive 14         | 0x00              | ok
        Drive 15         | 0x00              | ok
        Power Supply 1   | 0x01              | ok
        Power Supply 2   | 0x01              | ok
        Power Backplane  | 0x01              | ok
        PS 1 Fan Fault   | 0x01              | ok
        PS 2 Fan Fault   | 0x01              | ok
        PS 1 Therm Fault | 0x01              | ok
        PS 2 Therm Fault | 0x01              | ok
        PS1 12V OV Fault | 0x01              | ok
        PS2 12V OV Fault | 0x01              | ok
        PS1 12V UV Fault | 0x01              | ok
        PS2 12V UV Fault | 0x01              | ok
        PS1 12V OC Fault | 0x01              | ok
        PS2 12V OC Fault | 0x01              | ok
        PS 1 VCO Fault   | 0x01              | ok
        PS 2 VCO Fault   | 0x01              | ok
        Power Unit       | 0x01              | ok
        NMI State        | 0x00              | ok
        RAID Error       | 0x00              | ok
        PCI Riser 1      | 0x02              | ok
        CPU 1            | 0x80              | ok
        CPU 2            | 0x00              | ok
        ABR Status       | 0x00              | ok
        All CPUs         | 0x00              | ok
        One of The CPUs  | 0x00              | ok
        DASD Backplane 1 | 0x01              | ok
        DASD Backplane 2 | 0x02              | ok
        DASD Backplane 3 | 0x02              | ok
        DASD Backplane 4 | 0x02              | ok
        PCIs             | 0x00              | ok
        CPUs             | 0x00              | ok
        DIMMs            | 0x00              | ok
        Sys Board Fault  | 0x00              | ok
        Firmware Error   | 0x00              | ok
        Progress         | 0x00              | ok
        SEL Fullness     | 0x00              | ok
        CPU 1 OverTemp   | 0x01              | ok
        CPU 2 OverTemp   | 0x01              | ok
        All PCI Error    | 0x00              | ok
        PCI 1            | 0x00              | ok
        PCI 2            | 0x00              | ok
        PCI 3            | 0x00              | ok
        PCI 4            | 0x00              | ok
        PCI 5            | 0x00              | ok
        PCI 6            | 0x00              | ok
        PCI 7            | 0x00              | ok
        PCI 8            | 0x00              | ok
        CPU Fault Reboot | 0x00              | ok
        Aux Log          | 0x00              | ok
        One of PCI Error | 0x00              | ok
        DIMM 1           | 0x00              | ok
        DIMM 2           | 0x40              | ok
        DIMM 3           | 0x40              | ok
        DIMM 4           | 0x00              | ok
        DIMM 5           | 0x00              | ok
        DIMM 6           | 0x40              | ok
        DIMM 7           | 0x00              | ok
        DIMM 8           | 0x40              | ok
        DIMM 9           | 0x00              | ok
        DIMM 10          | 0x00              | ok
        DIMM 11          | 0x00              | ok
        DIMM 12          | 0x00              | ok
        DIMM 13          | 0x00              | ok
        DIMM 14          | 0x00              | ok
        DIMM 15          | 0x00              | ok
        DIMM 16          | 0x00              | ok
        DIMM 1 Temp      | 0x00              | ok
        DIMM 2 Temp      | 0x01              | ok
        DIMM 3 Temp      | 0x01              | ok
        DIMM 4 Temp      | 0x00              | ok
        DIMM 5 Temp      | 0x00              | ok
        DIMM 6 Temp      | 0x01              | ok
        DIMM 7 Temp      | 0x00              | ok
        DIMM 8 Temp      | 0x01              | ok
        DIMM 9 Temp      | 0x00              | ok
        DIMM 10 Temp     | 0x00              | ok
        DIMM 11 Temp     | 0x00              | ok
        DIMM 12 Temp     | 0x00              | ok
        DIMM 13 Temp     | 0x00              | ok
        DIMM 14 Temp     | 0x00              | ok
        DIMM 15 Temp     | 0x00              | ok
        DIMM 16 Temp     | 0x00              | ok
        Now I can monitor, for example, the "Fan 1 Tach" information (I get 1750 RPM as the result). However, when I try to monitor "Drive 0" (the result should be 0x01), I got a not supported error in Zabbix. I mean, I can only monitor things that result in Text or Number.
        Is it the "Type of information" that I'm missing here? I tried setting it to Numeric (unsigned) + Hexadecimal but it didn't work.
        Thanks a lot!
        • sire
          • Jul 2010
          • 210
          #19
          Hello, Andre!
          Register and vote for this feature here.
          Hello again Sergey.
          VRD              | 0x00              | ok
          Fan 1            | 0x01              | ok
          Fan 2            | 0x01              | ok
          Fan 3            | 0x01              | ok
          Drive 0          | 0x01              | ok
          Drive 1          | 0x01              | ok
          Drive 2          | 0x01              | ok
          Drive 3          | 0x01              | ok
          Drive 4          | 0x01              | ok
          Drive 5          | 0x01              | ok
          Drive 6          | 0x00              | ok
          Drive 7          | 0x00              | ok
          Drive 8          | 0x00              | ok
          Drive 9          | 0x00              | ok
          CPU 1            | 0x80              | ok
          CPU 2            | 0x00              | ok
          PCIs             | 0x00              | ok
          CPUs             | 0x00              | ok
          DIMMs            | 0x00              | ok
          PCI 1            | 0x00              | ok
          PCI 2            | 0x00              | ok
          PCI 3            | 0x00              | ok
          PCI 4            | 0x00              | ok
          PCI 5            | 0x00              | ok
          PCI 6            | 0x00              | ok
          PCI 7            | 0x00              | ok
          PCI 8            | 0x00              | ok
          Aux Log          | 0x00              | ok
          DIMM 1           | 0x00              | ok
          DIMM 2           | 0x40              | ok
          DIMM 3           | 0x40              | ok
          DIMM 4           | 0x00              | ok
          DIMM 5           | 0x00              | ok
          DIMM 6           | 0x40              | ok
          DIMM 7           | 0x00              | ok
          DIMM 8           | 0x40              | ok
          DIMM 9           | 0x00              | ok
          DIMM 10          | 0x00              | ok
          DIMM 11          | 0x00              | ok
          DIMM 12          | 0x00              | ok
          DIMM 13          | 0x00              | ok
          DIMM 14          | 0x00              | ok
          DIMM 15          | 0x00              | ok
          DIMM 16          | 0x00              | ok
          Thanks a lot!
          Regards,
          Sergey Syreskin
          • ZabbixSon
            • Nov 2014
            • 17
            #20
            What should i put?
            Hello Sire,
            i have some question about the template, what should i put here?
            <useip>*****</useip>
            <dns>*****</dns>
            <ip>*****</ip>
            <port>*****</port>
            <status>*****</status>
            <useipmi>*****</useipmi>
            <ipmi_ip>*****</ipmi_ip>
            <ipmi_port>*****</ipmi_port>
            <ipmi_authtype>*****</ipmi_authtype>
            <ipmi_privilege>*****</ipmi_privilege>
            <ipmi_username>*****</ipmi_username>
            <ipmi_password>*****</ipmi_password>
            Regards,
            ZabbixSon
            • sire
              • Jul 2010
              • 210
              #21
              Hi ZabbixSon,
              These vallues are set in GUI, not in the template file. Please see Zabbix manual on IPMI.
              Regards,
              Sergey Syreskin
