Logfile monitoring =>> COMPLETE SOLUTION!!!!
  • Monitoring
    • Oct 2010
    • 10
    This post is about "homemade" logfile monitoring on a windows machine!!
    Once you have setted-up the server <-> agent connection, you are ready to monitor some stuff..
    But to monitor a log file, you have to do some other settings. ( will be explained later )
    First I will give you a right clarify how zabbix put all these things together.
    Within Zabbix there are serveral things:
    1 - Items
    2 - Triggers
    3 - Actions
    - items are just raw data sources and won't trigger any alert (even zabbix failing to collect data will just silently mark item as "unsupported")
    - triggers are logic that say - based on item data - whether things are running as expected and how bad (severity) it is if they're not
    - alerts / actions take triggers as input (with filtering) and then execute operations (messages, remote commands) as "output"
    What to do exactly Things are explaned by the logfile example
    I want to send an email when something ( the word: "error" ) exists in the log file. The logfile is located a the C:\ drive.
    The file is called log.log.
    The file-extension needs to be *.log. Otherwise it will NOT work!
    !!ITEMS!!
    Items are used to get the information
    Below there is an image with the item - settings
    !!TRIGGER!!
    After that, the item is used to generate the trigger:
    !!ACTION!!
    The trigger is used to "generate"an action.
    Otherwise the action is triggered by the trigger
    As shown in the pictures you can see that we need a active agent connection. So the server needs to ask something at the agent.
    Therfore.. check these settings:
    # This is a config file for Zabbix Agent (Windows)
    # To get more information about Zabbix, go to http://www.zabbix.com
    ### Option: DebugLevel
    #	Specifies debug level
    #	0 - no debug
    #	1 - critical information
    #	2 - error information
    #	3 - warnings
    #	4 - for debugging (produces lots of information)
    # Mandatory: no
    # Default:
    DebugLevel=4
    ### Option: LogFile
    #	Name of log file.
    # Mandatory: no
    # Default:
    # LogFile=
    LogFile=C:\Program Files\Zabbix Agent\Zabbix_agentd.log
    ### Option: LogFileSize
    #	Maximum size of log file in MB.
    #	0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 1-1024
    # Default:
    # LogFileSize=1
    ### Option: SourceIP
    #	Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: EnableRemoteCommands
    #	Whether remote commands from Zabbix server are allowed.
    #	0 - not allowed
    #	1 - allowed
    # Mandatory: no
    # Default:
    [COLOR="red"]EnableRemoteCommands=1[/COLOR]
    ##### Passive checks related
    ### Option: Server
    #	List of comma delimited IP addresses (or hostnames) of Zabbix servers.
    #	No spaces allowed. First entry is used for receiving list of and sending active checks.
    #	Note that hostnames must resolve hostname->IP address and IP address->hostname.
    # Mandatory: yes
    # Default:
    # Server=
    Server=192.168.0.246
    ### Option: Hostname
    #	Unique hostname.
    #	Required for active checks and must match hostname as configured on the server.
    # Default:
    # Hostname=system.uname
    [COLOR="red"]Hostname=MonClient3[/COLOR]
    ### Option: ListenPort
    #	Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    [COLOR="red"]ListenPort=10050[/COLOR]
    ### Option: ListenIP
    #	Agent will listen on the specified interface.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    #Not original needed
    #ListenIP=192.168.0.246
    ### Option: DisablePassive
    #	Disable passive checks. The agent will not listen on any TCP port.
    #	Only active checks will be processed.
    #	0 - do not disable
    #	1 - disable
    # Mandatory: no
    # Default:
    # DisablePassive=0
    ##### Active checks related
    ### Option: DisableActive
    #	Disable active checks. The agent will work in passive mode listening for server.
    # Mandatory: no
    # Default:
    # DisableActive=0
    # DisableActive=1
    ### Option: ServerPort
    #	Server port for retrieving list of and  sending active checks.
    # Mandatory: no
    # Default:
    [COLOR="red"]ServerPort=10051[/COLOR]
    ### Option: RefreshActiveChecks
    #	How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    #	Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    #	Maximum number of values in a memory buffer. The agent will send
    #	all collected data to Zabbix Server or Proxy if the buffer is full.
    # Mandatory: no
    # Range: 1-65535
    # Default:
    # BufferSize=100
    ### Option: MaxLinesPerSecond
    #	Maximum number of new lines the agent will send per second to Zabbix Server
    #	or Proxy processing 'log' and 'eventlog' active checks.
    #	The provided value will be overridden by the parameter 'maxlines',
    #	provided in 'log' or 'eventlog' item key.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxLinesPerSecond=100
    ############ ADVANCED PARAMETERS #################
    ### Option: StartAgents
    #	Number of pre-forked instances of zabbix_agentd that process passive checks.
    # Mandatory: no
    # Range: 1-16
    # Default:
    StartAgents=5
    ### Option: Timeout
    #	Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: Include
    #	You may include individual files or all files in a directory in the configuration file.
    # Mandatory: no
    # Default:
    # Include=
    # Include=c:\zabbix\zabbix_agent.userparams.conf
    # Include=c:\zabbix\zabbix_agentd\
    ### Option: UserParameter
    #	User-defined parameter to monitor. There can be several user-defined parameters.
    #	Format: UserParameter=<key>,<shell command>
    #	Note that shell command must not return empty string or EOL only.
    #	Example: UserParameter=system.test,echo 1
    #UserParameter=system.test,echo 1
    [/QUOTE]
    I think ( because the time ), that everything is clear for now.
    If you have questions....
    Post a reaction. I will react within 1 day / 24 hours.. (99% uptime)
    Greets Gerard
  • JeyMulla
    • Sep 2010
    This is very helpful however I cannot see the picture of the trigger you created following:
    !!TRIGGER!!After that, the item is used to generate the trigger:
    Could you post this picture up again please,
    Many Thanks!!!
    Jey!
    • Monitoring
      • Oct 2010
      • 10
      Thanks for your reaction
      The underlayed code was oke..
      But I think that imageshack has hacked my picture hahaha
      Good luck!
      Greets Gerard.
      I can also recommend you the Zabbix book.
      • sbedoya
        • May 2009
        • 14
        Hi monitoring,
        I can't see the image of Triggers, can you fix it please, or explain how to.
        Thanks very much!!
        Santi
        • Colttt
          • Mar 2009
          • 878
          in Linux you must add the zabbix user to group adm.. otherwise permission denied..
          Debian-User
          Sorry for my bad english
          • harishgupta111
            • Nov 2011
            • 41
            Can we make graph from Log file monitored data
            Nice example.
            Can we make graph from the log file monitored data. Please suggest is it possible and if so then how?
            I tried adding the item into a graph but it shows "no data".
            Thanks a lot.
            • Tractorboy
              • Oct 2010
              • 98
              Triggers More Complex
              I have a log file
              01-01-2011 09:10:00 ERROR System Error Occurred
              01-01-2011 09:11:04 ERROR System Error Occurred
              01-01-2011 09:14:07 ERROR System Error Occurred
              01-01-2011 09:15:03 ERROR Application Error Occurred
              01-01-2011 09:17:06 ERROR System Error Occurred
              01-01-2011 09:19:00 ERROR Application Error Occurred
              01-01-2011 09:21:00 ERROR System Error Occurred
              I'd like a trgger to fire
              1) When a new error appears and that trigger stays active until 10 minutes after its last occurance
              2) When a different error occurs then a new trigger should fire.
              In the above example
              1) a trigger should fire at 09:10:00, system error occurred, that trigger would close at 09:31, as that is 10 minutes after the last occurance of that error.
              2) A new trigger should fire at 09:15:03, and that would close at 09:29:00, as that is 10 minutes after the last occurance of that error.
              • caraconan
                • Oct 2012
                Just in case that you want to test a solution based and SNMP without zabbix agent:
                Regards
                • tremo
                  • Mar 2016
                  • 11
                  i don't see any pictures.
                  I need it
                  • tritsako
                    • Dec 2014
                    • 46
                    i don't see any pictures either
                    How can we have these pictures for the examples?
