Hi all !
I got some questions about performance. For the moment my Zabbix server is functionnal but some checks which are configured to be checked each 60 seconds takes 120 seconds to be checked. I can see that in the "Latest Data" tab.
If the trigger is planned to warn us after 3 failures (.max(#3)) I should receive the message 3 minutes after the first failure. But in fact I receive it 6 minutes after.
So I think I got a performance issue.
I have:
Hosts: 458 (408/9/41)
Items: 24001 (10595/4152/9254)
Triggers: 5347 (5321/21 [40/336/4950])
Required server performance: 151,16
The load on the server is quite low, 0.51 and there is 5Go of Ram. Processor is a Xeon 3,4GHz with 4 cores.
The Database is in InnoDB with replication on a second server.
I don't really know where to start to improve performance and tune it. i would like the checks to really check on the configured interval and not the double.
If you have any info or question to help us, feel free
Thank you for your time !
PS: There is a mysql replication on another server in case the first one crashes. On this one Zabbix is shutdown to prevent double checks. There is also website that use the MySQL replication on the second server but it's not an heavy use.
I have:
