TP-Link WiFi Router Archer VR900 & WiFi Extender WA901
  • Gokiwi64
    • Jun 2020
    • 36
    So both of these devices have snmp 1/2c functionality , and work with the built in TP-Link template however they misreport interface speeds and miss out a couple of interfaces - snmpwalk shows these interface speeds and shows up the missing interfaces.
    How do I add them in to either the existing TP-Link template or create a new one.
  • Hamardaban
    • May 2019
    • 2714
    The interfaces of the device are detected by the LLD when it has filtered out the junk. You can change the filter as you need or remove it altogether.
    • Gokiwi64
      • Jun 2020
      • 36
      Hi, Many thanks for that - Unfortunately all way above my ability/knowledge level.I'm just a simple router/switch engineer not a developer/rocket scientist.
      • Gokiwi64
        • Jun 2020
        • 36
        For reference this is what an snmp walk finds/reports
        Name/OID: ifIndex.2; Value (Integer): 2
        Name/OID: ifIndex.4; Value (Integer): 4
        Name/OID: ifIndex.8; Value (Integer): 8
        Name/OID: ifIndex.16; Value (Integer): 16
        Name/OID: ifIndex.21; Value (Integer): 21
        Name/OID: ifIndex.23; Value (Integer): 23
        Name/OID: ifDescr.2; Value (OctetString): ifb0
        Name/OID: ifDescr.4; Value (OctetString): gre0
        Name/OID: ifDescr.8; Value (OctetString): bcmsw
        Name/OID: ifDescr.16; Value (OctetString): br0
        Name/OID: ifDescr.21; Value (OctetString): tun0
        Name/OID: ifDescr.23; Value (OctetString): ppp1
        Name/OID: ifType.2; Value (Integer): ethernetCsmacd (6)
        Name/OID: ifType.4; Value (Integer): ethernetCsmacd (6)
        Name/OID: ifType.8; Value (Integer): ethernetCsmacd (6)
        Name/OID: ifType.16; Value (Integer): ethernetCsmacd (6)
        Name/OID: ifType.21; Value (Integer): ethernetCsmacd (6)
        Name/OID: ifType.23; Value (Integer): ppp (23)
        Name/OID: ifMtu.2; Value (Integer): 1500
        Name/OID: ifMtu.4; Value (Integer): 1476
        Name/OID: ifMtu.8; Value (Integer): 1500
        Name/OID: ifMtu.16; Value (Integer): 1500
        Name/OID: ifMtu.21; Value (Integer): 1500
        Name/OID: ifMtu.23; Value (Integer): 1480
        Name/OID: ifSpeed.2; Value (Gauge): 100000000
        Name/OID: ifSpeed.4; Value (Gauge): 100000000
        Name/OID: ifSpeed.8; Value (Gauge): 100000000
        Name/OID: ifSpeed.16; Value (Gauge): 100000000
        Name/OID: ifSpeed.21; Value (Gauge): 100000000
        Name/OID: ifSpeed.23; Value (Gauge): 0
        I dont know how to show what zabbix reports easily unfortunately
