Send SMS with delay
  • Aminam
    • Nov 2020
    Send SMS with delay
    Have you ever wanted to receive a SMS of a trigger after a specified time ?
    to do so, you have to set steps in your "action".
    here is one example which i did on my zabbix 5.0.9 for sending SMS.
    go to Action and click on desired action then navigate to "operation" tab.
    in the first textbox on the above set your default step duration or you can set it later on operation section. for instance i set that 300(s).
    now on the below, operation, you should determine after how much time the action must triggered ?
    if you want to send sms after 5 minutes you should set "steps" : 2-2.
    you also can increase the time by changing the default duration step.
    Oh, you followed chapter of escalations from manual... Doesn't it feel good, when you read something and it actually works as described?
    • Aminam
      Aminam commented
      and yet some people are unable to find out this solution on your linked url, what a funny world.
