devices which have no clients installed (eg Printers) , how they are monitored
  • bisana
    • Jul 2005
    • 87
    HI All,
    Good afternoon
    like to request for the docs url in which I can read about how to monitor printers ( no snmp or no agent on the printer)
    Appreciate for the support so far
    thanks
    Joseph John
    If you dont have even snmp, then basically it is a black box... you can probably ping it, but it is as useful as pinging a kettle of water... you may know, that there is electricity, but is the water cold or hot...no idea..
    • LenR
      • Sep 2009
      • 1011
      The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
      Your printer is probably running SNMP unless you have done something to disable it.
