Announcement
No announcement yet.
Snmp_builder for zabbix 3.2
  • Filter
    Hello, everyone.
    I've just made some effort on porting snmp_builder plugin to zabbix 3.2. Seems to work, testers and bug reports appreciated.
    Locates here - https://github.com/mickvav/snmpbuilder/
    Originally posted by mickvav View Post
    Hello, everyone.
    Very Good Iniciative !
    What do you think about integrate with EveryZ ?
    Adail Horst
    OCA/OCP - Oracle Application Server
    ZABBIX Certified Specialist
    http://www.spinola.net.br/blog (Blog sobre Zabbix e tecnologia)
      Nice idea.
      Not sure if I'll have free time to do it in near future, but it seems to be an important next step.
        Nice idea.
        Mickvav,
        I can help with this change... if you still working with SNMPBuilder code in nexts releases of Zabbix
        EveryZ can help with Integration with Zabbix... and you still mantain the SNMPBuilder module code... what do you think ?
        Adail Horst
          Hello, everyone.
          Hi, I integrated snmp_builder and got an error, please help
          error
          Cannot find module (SNMPv2-SMI): At line 13 in /usr/share/snmp/mibs/F5-BIGIP-LOCAL-MIB txt Cannot find module (SNMPv2-SMI): At line 13 in /usr/share/snmp/mibs/F5-BIGIP-LOCAL-MIB.txt
            error
            Had same problem fix that in next way
            use
            #download-mibs it downloaded mibs to dir in config file
            cat /etc/snmp-mibs-downloader/snmp-mibs-downloader.conf
            # Master configuarion for mib-downloader
            BASEDIR=/var/lib/mibs
            then copy from /var/lib/mibs/iana and ietf to folder /usr/share/snmp/mibs/
            BUT!!! after that i still have problem , just have empty page without errors
            Who can help with it ??
              use
              Check the path to the scripts, it seems there is an error (Проверь путь к скриптам, похоже там есть ошибка)
                Thanks! Yes it's work for me
                I just do not have path to scripts
                  Just tried this on 3.2. I get sutck at the edit include/menu.inc.php with
                  * Open include/menu.inc.php. At line 203, insert a piece of code
                  array('url'=>'snmp_builder.php',
                  'label'=>'SNMP Builder'
                  Like this:
                  'label'=>S_NOTIFICATIONS
                  array('url'=>'locales.php',
                  'label'=>S_LOCALES
                  array('url'=>'instal.php',
                  'label'=>S_INSTALLATION,
                  'sub_pages'=>array('setup.php','warning.php')
                  as I can see any of that code in there?
                    Well, looks like they've made some changes in menu configuration system, so I've updated the documentation accordingly.
                      Looks like they've changed menu configuration system a little bit - I've updated README accordingly.
                        i have instales it in the version 3.4.5 and I see it, can with it work, but when I choose the MIB i have only this message on the bottom:
                        .MIB search path: /var/www/html/zabbix/snmp_builder/mibs:/usr/share/snmp/mibs:/home/appliance/ snmp/mibs/ MIB search path: /var/www/html/zabbix/snmp_builder/mibs:/usr/share/snmp/mibs:/home/appliance/.snmp/mibs
                        but I doesn't see anything in the Tree view and can save anything.
                        • Alfista
                          Alfista commented
                          I use the 3.4.5 appliance. Please can you tell me where can be the problem, that I can use the importer. Thanks.
                        Tested on Zabbix 3.4.6. When I clique in save, I recieved the error:
                        Incorrect value for field "history": must be between "3600" and "788400000".
                        Just change:
                        snmp_builder.php
                        Line 240: 'history' => 90,
                        To a value between the interval and OK!
                          Hi, I search way how to write templates for zabbix from MIB files.
                          I am with lates zabbix 3.4 + version.
                          What is the right start point ?
                            I have the same screen but only with the error mesage as decribed beloow.
                            I hahe check the all installed componets and all are as decribed in the mnaual.
                            [ATTACH]10145[/ATTACH]
