Translation of ZABBIX GUI. Help needed!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    #46
    Hmm, you're right. I have to check if we have a proper russian translation somewhere.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Beam
      • May 2007
      • 12
      #47
      I created a new german version, it supports now 1.4.1.
      Thx to the previous version to jpawslowski.
      In the array, there are no entries for
      • The trigger depends on
      • No dependences defined
      • New dependency
      Which are shown in the triggers.php, when you add a trigger.
      • Press here to disconnect/reconnect
      Which appears, after the login couldn't also be translated.
      Is it possible to add this manually?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        #48
        Thanks! It was integrated into pre 1.4.2.
        Alexei Vladishev
        My Twitter
        • hiddenman
          • Dec 2005
          • 18
          #49
          Alexey, i translated 1.1.5 in February (http://www.zabbix.com/forum/showthread.php?t=4938). Did you check it? If it's good enough, i can make updates for the 1.4.2
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            #50
            Integrated into 1.4.x. Thank you!
            Alexei Vladishev
            My Twitter
            • hiddenman
              • Dec 2005
              • 18
              #51
              You are welcome
              So, does it need any updates? I'll recheck the translation.
              • nonaka_nona_to
                • Sep 2007
                • 9
                #52
                new japanese translation
                Hello, zabbix developers.
                A new japanese translation for zabbix-1.4.2.
                $ wc -l ...
                 802 zabbix-1.4.2/frontends/php/include/locales/ja_jp.inc.php
                1325 zabbix-1.4.2/frontends/php/include/locales/en_gb.inc.php
                1325 ja_jp.inc.php-1.4.2
                • antani
                  • Apr 2008
                  • 50
                  #53
                  Originally posted by Lovespider
                  ...For instance the word "trigger" is not so simple to translate...
                  I'd love if "trigger" would not be translated. It does make perfect sense in italian and other words will definitely lead in misunderstooding. For instance Trigger is left trigger in famous products as MS SQL and Backup Exec. Italian users are used to "trigger" word.
                  Mi piacerebbe se trigger non fosse tradotto. Ha perfettamente senso in italiano e qualsiasi altra parola porterebbe a fraintendimenti. Per esempio Trigger non è tradotto in programmi quali MS SQL e Backup Exec.
                  • Tenzer
                    • Nov 2007
                    • 316
                    #54
                    Are there going to be big changes in the template file from 1.4.x to 1.6?
                    I presume that people wanting to translate Zabbix now should use the template file from CVS?
                    • leomazzo
                      • Mar 2008
                      To Alexei - pt_br.inc.php for 1.5.2
                      Alexei,
                      This is the file with the translation of new menu items for Portuguese (Brazil). The new itens that i´ve included are "Locales" and "Authentication".
                      Regards.,
                      Leonardo Matarazzo.
                      São Paulo - Brazil.
                      • Kodai
                        • Mar 2006
                        new Japanese version
                        I created a new Japanese version for 1.4.5.
                        And, I created a patch for following problems:
                        * In the en_gb.inc.php, there are no entries for some terms.
                        * There is duplicate term "S_LABEL".
                        * Web frontend is not updated when I update translation file.
                        Please see attachment for details.
                        Kodai Terashima
                        [URL="http://www.zabbix.jp"]ZABBIX-JP[/URL] - Japanese Zabbix community
                        • Kodai
                          • Mar 2006
                          New Japanese version and Korean translation
                          Hello ZABBIX developers,
                          I created a new Japanese version for 1.4.6,
                          and My friend created a Korean translation for 1.4.6.
                          Kodai Terashima
                          • Cirrus
                            • Oct 2004
                            Polish translation
                            Here is the Polish translation, based on the file en_gb.inc.php included in Debian unstable package:
                            zabbix-frontend-php_1.6.2-1_all.deb
                            All the lines have been translated. File formatting has been improved too.
                            Jarek Pioro
                            Cirrus - Aedificaremus Tibi
                            Cirrus oferuje Państwu kompleksową obsługę informatyczną firmy w ramach outsourcingu. Świadczymy komercyjne wsparcie dla systemów (Debian,Ubuntu,Red Hat,SuSE).
                            • Kodai
                              • Mar 2006
                              Update Japanese translation for 1.6.x
                              I created a Japanese translation for 1.6,x.
                              Kodai Terashima
                              • Alexei
                                Founder, CEO
                                • Sep 2004
                                • 5654
                                #60
                                Thank you! It has been integrated into 1.6.x and trunk.
                                Alexei Vladishev
                                My Twitter
