pre-zabbix-1.8.3.x-12788
  • Filter
    I have installed zabbix 1.8.2 stable from ports on FreeBSD 8.0
    When I install from sources pre-zabbix-1.8.3.x-12788 and run zabbix server, i found that zabbix server don't start and in log:
    58355:20100616:172325.312 Starting Zabbix Server. Zabbix 1.8.3 (revision 12779).
    58355:20100616:172325.312 **** Enabled features ****
    58355:20100616:172325.312 SNMP monitoring: YES
    58355:20100616:172325.312 IPMI monitoring: NO
    58355:20100616:172325.312 WEB monitoring: YES
    58355:20100616:172325.312 Jabber notifications: YES
    58355:20100616:172325.312 ODBC: YES
    58355:20100616:172325.312 SSH2 support: YES
    58355:20100616:172325.312 IPv6 support: NO
    58355:20100616:172325.313 **************************
    58355:20100616:172327.394 server #0 started [Watchdog]
    58356:20100616:172327.395 server #1 started [DB Cache]
    58365:20100616:172327.433 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    58365:20100616:172327.433 ====== Fatal information: ======
    58365:20100616:172327.433 program counter not available for this architecture
    58365:20100616:172327.433 === Registers: ===
    58365:20100616:172327.433 register dump not available for this architecture
    58365:20100616:172327.433 === Backtrace: ===
    58365:20100616:172327.433 backtrace not available for this platform
    58365:20100616:172327.433 === Memory map: ===
    58365:20100616:172327.433 memory map not available for this platform
    58365:20100616:172327.433 ================================
    58366:20100616:172327.435 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    58366:20100616:172327.436 ====== Fatal information: ======
    58366:20100616:172327.436 program counter not available for this architecture
    58366:20100616:172327.436 === Registers: ===
    58366:20100616:172327.436 register dump not available for this architecture
    58366:20100616:172327.436 === Backtrace: ===
    58366:20100616:172327.436 backtrace not available for this platform
    58366:20100616:172327.436 === Memory map: ===
    58366:20100616:172327.436 memory map not available for this platform
    58366:20100616:172327.436 ================================
    58357:20100616:172327.464 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x10]. Crashing ...
    58357:20100616:172327.464 ====== Fatal information: ======
    58357:20100616:172327.464 program counter not available for this architecture
    58357:20100616:172327.464 === Registers: ===
    58357:20100616:172327.464 register dump not available for this architecture
    58357:20100616:172327.464 === Backtrace: ===
    58357:20100616:172327.464 backtrace not available for this platform
    58357:20100616:172327.464 === Memory map: ===
    58357:20100616:172327.464 memory map not available for this platform
    58357:20100616:172327.464 ================================
    58377:20100616:172327.469 server #22 started [Trapper]
    58379:20100616:172327.469 server #24 started [Trapper]
    58381:20100616:172327.470 server #26 started [Trapper]
    58383:20100616:172327.470 server #28 started [Alerter]
    58385:20100616:172327.470 server #30 started [Timer]
    58387:20100616:172327.470 server #32 started [HTTP Poller]
    58389:20100616:172327.470 server #34 started [DB Syncer]
    58391:20100616:172327.471 server #36 started [DB Syncer]
    58393:20100616:172327.471 server #38 started [Escalator]
    58355:20100616:172327.471 One child process died (PID:58365,exitcode/signal:65280). Exiting ...
    58372:20100616:172327.471 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58356:20100616:172327.471 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58374:20100616:172327.472 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58359:20100616:172327.472 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58376:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58361:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58363:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58378:20100616:172327.473 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58367:20100616:172327.474 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58382:20100616:172327.474 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58369:20100616:172327.475 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58384:20100616:172327.475 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58371:20100616:172327.475 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58386:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58373:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58388:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58375:20100616:172327.476 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58377:20100616:172327.477 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58390:20100616:172327.477 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58379:20100616:172327.478 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58392:20100616:172327.478 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58381:20100616:172327.478 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58358:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58383:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58362:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58360:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58385:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58364:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58387:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58368:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58389:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58370:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58391:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58380:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58393:20100616:172327.479 Got signal [signal:15(SIGTERM),sender_pid:0,sender_uid:0,reaso n:0]. Exiting ...
    58355:20100616:172329.484 Syncing history data...
    58355:20100616:172329.484 Syncing history data... done.
    58355:20100616:172329.484 Syncing trends data...
    58355:20100616:172329.484 Syncing trends data... done.
    58355:20100616:172329.484 Zabbix Server stopped. Zabbix 1.8.3 (revision 12779).
    What is it "program counter not available for this architecture" and zabbix server don't start?
    interesting. please report it on the tracker
    Zabbix tips and inspiration (blog)
      Ok, https://support.zabbix.com/browse/ZBX-2559
        make portupgrade net-snmp to version 5.5, it's resolv problem
          new problem with pre-zabbix-1.8.3.x-12896
          1. When i make search host with "QUICK SEARCH", appear error
          Undefined index: excludePattern[/usr/local/www/apache22/data/api/classes/class.chost.php:459]
            thanks, this should be fixed now. btw, it's better to report problems on the tracker, because then there's less chance for them to go unnoticed
              OK, https://support.zabbix.com/browse/ZBX-2578
              Announcement
              No announcement yet.
