I have a slide show setup to delay 60 seconds between each slide, but it is flipping every 5 seconds since I did the update about 20min ago. Its in my peripheral vision on the monitoring screen and driving me bonkers!
1.8.3rc3 - Slideshow gone nuts!
Are you sure that refresh rate for the individual screens of the slide show is also set to 60 seconds or left default? -
How do you set the refresh rate for an individual screen?
The user refresh rate is set to 120 seconds (but I understand this is now ignored for slide shows?).
I have tried different combinations of "Update interval" for the whole slide show and delay between each slide but its constantly rotating at 5 seconds between each slide regardless.Comment
if refresh rate selector in slideshow viewing has an option "120", it's not 1.8.3rc3Comment
Under Configuration and in Slides, "Update interval (in sec)" pull down lists options from 10 - 900, 120 is an option there. I am definitely running 1.8.3rc3.
Edit: Also IRC seems so quiet without you there
Edit2: Just doing some more testing, I created a brand new slide show with exactly the same options and I am not seeing the same problem. Possibly something to check into for others upgrading?Last edited by noxis; 09-08-2010, 11:03.Comment
in 1.8.3rc3 refresh rate selector should be in multiples, not absolute seconds (x0.25, x0.5, x1, x2 etc)
heh, some technical issues to resolve...Comment
I had my morning can of Red Bull and read again what you put, it made more sense then.
The pull down lists 10 - 900 with 120 being the 4th option. I am definitely running 1.8.3rc3.Comment
Was a fresh dir for the install, only thing I copied over was the configuration file with db details in etc... Straight from the rc3 tarball on the download section.Comment
ahhhh. but that's a dialog for slideshow configuration.
i was referring to the dropdown available in slideshow viewing page instead
When I was preparing this one request https://support.zabbix.com/browse/ZBX-2852 (as I was preparing him for a long time)
I have several times situation arises when the drop-down list of multiplier were not allocated any points at all (that is, even the default multiplier "x1" was not selected) In this case, the slides I'm really at a rate of approximately 5,5 seconds (although the individual values of Delays were considerably more).
I also wanted to publish it in the request but was not able to clearly reproduce the problem.
After cleaning the table "profiles" I could not manage to reproduce the problem.
If the table was empty, then the multiplier is always inserted "x1".Comment
do you have a backup with contents of that table that allow to reproduce the problem ?
that would be a significant help to figure out what might have been going on.
i tried to reproduce by using 1.8.2 first, then 1.8.3 - while initially no multiplier is selected (which might be a minor bug), but after selecting one everything is saved correctlyComment
I have the backup of three months old, I can try to reproduce the problem when come to me Inspiration
Do I try to do it?
yes, after selecting one everything is saved correctly.Comment
well, if you can reproduce the problem of not being able to save the multiplier, that would be very nice to fix.Comment
