Just installed and played around with 1.1b6 for an hour and no major problems found over b5 so far (Zabbix is running and collecting data for my previously defined hosts/items etc).
1) Gui Cleanup: Clone/Copy ability in Items is Lost
It is no longer possible to copy an existing item to a new item. In 1.1b5 it was possible to open an existing item, make a modification (inluding new descr and key) and then select "Add" to create a new item. The "Add" and "Update" buttons have now been replaced with one button "Save". Suspect several other tabs have also lost similar functionality (e.g triggers).
Can we have a "Clone", "Copy" or "Add New" function tio Items and Triggers in 1.1b7? This was a big timesaver especially for adding lots of similar Items or testing out different Item configurations.
2) SNMP problems disables host (in Zabbix).
Having only spent a few days with SNMP in Zabbix I'm still verifying this as a problem and workaround. I saw this behavior in b5 as well.
If an SNMP value cannot be retrieved (such as misconfiguration of OID, Community etc) then the host is marked as down (in the zabbix logs this appears as an error "Timeout while connecting to [$host_ip:$snmp_port]"
Although the host is available no more values will be collected for any other correctly defined items. The workaround seems to be to disable/delete the offending item and then (occasionaly) go to the host configuration and save the status again as "monitored".
This does seem intermittent. Sometimes the misconfigured Item will be automatically deactivated and be shown with a status of "not supported". I do not believe (yet) this is a problem with the host or host connectivity but I'm trying to track this down.
In any case, the problem in zabbix seems to be when the host is marked as "timeout" because one value is unavailable, no other values are collected from the host until the host is marked as available again. This does make sense, but is it possible for an enhancement that will make 2 or more sequential checks of any Item on a host before marking the host as unavailable?
3) Feature Request: SNMP Calc
As you asked for any remaining Feature Requests for 1.1. I found an old request out there in the sourceforge forums for the following. I would like to add my vote for this feature:
"I'd like to know if it is possible to define calculated items using formulas (Ex. : used bandwidth, using ifInOctets, ifOutOctets, and ifSpeed), to have more "high level" items"
thanks
Mark
thanks
Mark
