Simple check: "TCP,Port" not working.
  • safl
    • May 2005
    • 103
    Regards,
    The simple check: "tcp,port" isn't working in beta6.
    I just upgraded from beta2.
    Running Debian Etch, MySQL 5.0, PHP 5. Zabbix compiled from source.
    I get "0" on all my "tcp,port" simple checks. Normal simple checks are working just fine (http, imap etc.).
    net.tcp.port[<ip>,port] is not usable since it is not a "SIMPLE check" but "agent check". And the purpose of simple check is to monitor ports where agent is not available.
    Another guy has reported this problem with beta5 as well.
    Any resolution to this?
    Regards,
    Simon
  • bbrendon
    • Sep 2005
    • 873
    Thanks helping me keep my sanity.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • crs9
      • Feb 2006
      • 35
      I'm having this same issue in b7? Still an issue or is the issue with me? lol
      • bbrendon
        • Sep 2005
        • 873
        agreed.
        list of known problems.
        http://www.zabbix.com/doku/doku.php?...x#known_issues
        • sauron
          • Jan 2005
          • 215
          Contain fix. I'm think it's temporaly solution.
          • globe
            • Apr 2006
            • 40
            can i use this patch also with beta1.8? because i do not get simple tcp probes to run; returns always "0"
