beta8 disabling item in template does not disable it in the host.
  • azilber
    • Apr 2005
    • 33
    All,
    When you disable an item in a linked template, that item is not disabled in the host. It's still visible both under that hosts items AND under latest views.
    Also, clearing history on those items has no affect. Only deleting the items helps.
    -Alex
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    This will be implemented in next beta.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • edeus
      • Aug 2005
      • 120
      It would be good if there was some kind of option to save this change to all linked hosts or only on the template.
      If what you are suggesting will be in the next beta, this would be fairly annoying if I decided to update a template to have more "disabled by default" items.
      • bbrendon
        • Sep 2005
        • 873
        Agreed. I often find myself changing the template because the template is the default.
        Unofficial Zabbix Expert
        Blog, Corporate Site
