I'm using Zabbix for 3 to 4 years now and it's great.
But the few times I had to troubleshoot and needed zabbix_server.log I didn't really get any wiser.
In warning mode it gives way too little info even if things go wrong.
In Debug mode you get a lot of lines, but when it comes to giving info it comes short.
At this moment I'm having a problem after an update to the latest trunk.
There are 2 issues.
zabbix thinks all my Fritzbox 7390 are unreachable while they are not.
The Fritzbox 7270 uses the same binary and they are still reported as available.
Also all my other devices are reported as available.
Strange.......
I'm also getting a warning in my server log ever since.
But I'm missing the info which host is generating this error.. The IP would be enough for me.
I did a grep -B5 -A5 'Message size' and got this snippet out of the (debug) log....
is freetz.nm.xs4all generating this error?
13277:20120905:133443.905 query [txnlev:0] [select min(clock) from trends where itemid=25993]
13277:20120905:133443.905 In delete_history() table:'trends_uint' itemid:25993 keep_history:60 now:1346844669
13277:20120905:133443.905 query [txnlev:0] [select min(clock) from trends_uint where itemid=25993]
13277:20120905:133443.905 In delete_history() table:'history' itemid:25994 keep_history:7 now:1346844669
13277:20120905:133443.906 query [txnlev:0] [select min(clock) from history where itemid=25994]
13269:20120905:133443.906 Message size 72057594037927936 exceeds the maximum size 67108864 bytes. Message ignored.
13268:20120905:133443.906 get value from agent result: '0.006667'
13269:20120905:133443.906 Item [freetz.nm.xs4all:net.ping[192.168.188.10]] error: Get value from agent failed:
13268:20120905:133443.906 End of get_value():SUCCEED
13269:20120905:133443.906 End of get_value():NETWORK_ERROR
13268:20120905:133443.906 In activate_host() hostid:10067 itemid:23738 type:0
There are 2 issues.
Strange.......
