New installation of v1.1alpha6 on SuSE 9.2
After installing if I bring up theadministration tool and add a host ( same machine the server and db are located on ) the server process dies.
The bottom of the log file follows:
003124:20050306:142356 In DBnum_rows
003124:20050306:142356 No items to update.
003124:20050306:142356 Executing query:update hosts set network_errors=3 where hostid=10008
003124:20050306:142356 Spent 0 seconds while updating values
003124:20050306:142356 Executing query:select count(*),min(nextcheck) from items i,hosts h where ((h.status=0 and h.available!=2) or (h.status=0 and h.available=2 and h.disable_until<1110137036)) and h.hostid=i.hostid and i.status=0 and i.type not in (2) and i.itemid%1=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]')
003124:20050306:142356 Result of DBnum_rows [1]
003124:20050306:142356 Nextcheck:-1 Time:1110137036
003124:20050306:142356 Sleeping for 60 seconds
003122:20050306:142426 Executing query:select distinct f.itemid,f.functionid,f.parameter from functions f, items i,hosts h where h.hostid=i.hostid and ((h.status=0 and h.available!=2) or (h.status=0 and h.available=2 and h.disable_until<1110137066)) and i.itemid=f.itemid and f.function='nodata' and i.lastclock+f.parameter<=1110137066 and i.status=0 and i.type=2 and (f.lastvalue<>1 or f.lastvalue is NULL)
003122:20050306:142426 In DBnum_rows
003121:20050306:142426 Executing query:select a.alertid,a.mediatypeid,a.sendto,a.subject,a.messa ge,a.status,a.retries,mt.mediatypeid,mt.type,mt.de scription,mt.smtp_server,mt.smtp_helo,mt.smtp_emai l,mt.exec_path from alerts a,media_type mt where a.status=0 and a.retries<3 and a.mediatypeid=mt.mediatypeid order by a.clock
003121:20050306:142426 In DBnum_rows
003122:20050306:142456 Executing query:select distinct f.itemid,f.functionid,f.parameter from functions f, items i,hosts h where h.hostid=i.hostid and ((h.status=0 and h.available!=2) or (h.status=0 and h.available=2 and h.disable_until<1110137096)) and i.itemid=f.itemid and f.function='nodata' and i.lastclock+f.parameter<=1110137096 and i.status=0 and i.type=2 and (f.lastvalue<>1 or f.lastvalue is NULL)
003122:20050306:142456 In DBnum_rows
003121:20050306:142456 Executing query:select a.alertid,a.mediatypeid,a.sendto,a.subject,a.messa ge,a.status,a.retries,mt.mediatypeid,mt.type,mt.de scription,mt.smtp_server,mt.smtp_helo,mt.smtp_emai l,mt.exec_path from alerts a,media_type mt where a.status=0 and a.retries<3 and a.mediatypeid=mt.mediatypeid order by a.clock
003121:20050306:142456 In DBnum_rows
003123:20050306:142456 In create_host_file()
003123:20050306:142456 Executing query:select distinct h.ip from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1110137096)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and i.status=0 and h.useip=1
003123:20050306:142456 In DBnum_rows
003123:20050306:142456 Executing query:select distinct h.host from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1110137096)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and i.status=0 and h.useip=0
003123:20050306:142456 In do_ping()
003124:20050306:142456 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.ho stid,h.status,i.value_type,h.network_errors,i.snmp _port,i.delta,i.prevorgvalue,i.lastclock,i.units,i .multiplier,i.snmpv3_securityname,i.snmpv3_securit ylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassph rase,i.formula,h.available from items i,hosts h where i.nextcheck<=1110137096 and i.status=0 and i.type not in (2) and ((h.status=0 and h.available!=2) or (h.status=0 and h.available=2 and h.disable_until<=1110137096)) and h.hostid=i.hostid and i.itemid%1=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck
003124:20050306:142456 In DBnum_rows
003124:20050306:142456 Result of DBnum_rows [2]
003119:20050306:142456 One child process died. Exiting ...
003119:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003121:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003122:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003123:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003125:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003125:20050306:142456 Cannot remove PID file [/var/run/zabbix/server.pid] [No such file or directory]
003127:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003127:20050306:142456 Cannot kill process. PID=[3121] [No such process]
003127:20050306:142456 Cannot kill process. PID=[3122] [No such process]
003127:20050306:142456 Cannot kill process. PID=[3123] [No such process]
003127:20050306:142456 Cannot kill process. PID=[3124] [No such process]
003127:20050306:142456 Cannot kill process. PID=[3125] [No such process]
003127:20050306:142456 Cannot remove PID file [/var/run/zabbix/server.pid] [No such file or directory]
003128:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003128:20050306:142456 Cannot kill process. PID=[3121] [No such process]
003128:20050306:142456 Cannot kill process. PID=[3122] [No such process]
003128:20050306:142456 Cannot kill process. PID=[3123] [No such process]
003128:20050306:142456 Cannot kill process. PID=[3124] [No such process]
003128:20050306:142456 Cannot kill process. PID=[3125] [No such process]
003128:20050306:142456 Cannot remove PID file [/var/run/zabbix/server.pid] [No such file or directory]
003129:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003129:20050306:142456 Cannot kill process. PID=[3121] [No such process]
003129:20050306:142456 Cannot kill process. PID=[3122] [No such process]
003129:20050306:142456 Cannot kill process. PID=[3123] [No such process]
003129:20050306:142456 Cannot kill process. PID=[3124] [No such process]
003129:20050306:142456 Cannot kill process. PID=[3125] [No such process]
003129:20050306:142456 Cannot remove PID file [/var/run/zabbix/server.pid] [No such file or directory]
003130:20050306:142456 Got QUIT or INT or TERM or PIPE signal. Exiting...
003130:20050306:142456 Cannot kill process. PID=[3121] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3122] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3123] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3124] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3125] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3127] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3128] [No such process]
003130:20050306:142456 Cannot kill process. PID=[3129] [No such process]
003130:20050306:142456 Cannot remove PID file [/var/run/zabbix/server.pid] [No such file or directory]
