zabbix 1.4 won't compile on freebsd
  • andrew.p
    • Jun 2007
    FreeBSD 6.0-STABLE, net-snmp-5.3.1, zabbix-1.4.
    When using this configuration command:
    ./configure --with-mysql --enable-server --enable-agent --with-net-snmp
    I get this error message:
    checking for mysql_config... /usr/local/bin/mysql_config
    checking for main in -lmysqlclient ... yes
    checking for mysql_autocommit in MySQL... no
    checking for ZABBIX server database selection... ok
    checking for pkg-config... /usr/local/bin/pkg-config
    checking pkg-config is at least version 0.9.0... yes
    checking for gawk... (cached) nawk
    checking for curl-config... /usr/local/bin/curl-config
    checking for the version of libcurl... 7.16.1
    checking for libcurl >= version 7.15.1... yes
    checking for main in -lcurl... yes
    checking whether libcurl is usable... no
    checking for net-snmp-config... /usr/local/bin/net-snmp-config
    checking for main in -lnetsnmp ... no
    configure: error: Not found NET-SNMP library
    Some other info:
    # /usr/local/bin/net-snmp-config --libs
    -rpath=/usr/lib:/usr/local/lib -L/usr/local/lib -lnetsnmp -lcrypto -lm -lkvm -ldevstat -lwrap
    # /usr/local/bin/net-snmp-config --version
    5.3.1
    # /usr/local/bin/net-snmp-config --cflags
    -DINET6 -O2 -pipe -Dfreebsd6 -DAPPLLIB_EXP=/usr/local/lib/perl5/5.8.7/BSDPAN -DHAS_FPSETMASK -DHAS_FLOATINGPOINT_H -fno-strict-aliasing -pipe -I/usr/local/include -I/usr/local/lib/perl5/5.8.7/mach/CORE -I. -I/usr/local/include
    Also, I don't know if it's related, but have you noticed "checking whether libcurl is usable... no" message above?
    When running configuration script with '--with-libcurl=/usr/local', I am getting this:
    configure: error: Not found Curl library
    Same os similar issues have been reported in the past:
    ...but what I am in looks like a dead end.
  • proctozont
    • May 2007
    To fix curl try
    ./configure --with-libcurl=/usr/local
    For me it helped.
    to fix net-snmp try to edit file configure
    variable _libnetsnmp_libdir not defined
    I just add
    _libnetsnmp_libdir="`$_libnetsnmp_config --libs`"
    ufter
    if test "x$_libnetsnmp_config" != "x" ; then
    • andrew.p
      • Jun 2007
      Originally posted by proctozont
      To fix curl try
      For me it helped.
      I just add
      ufter
      Can you tell me what what version you are using? I can not find such test condition in 1.4. Also, I have posted above an error I get when running ./configure --with-libcurl=/usr/local.
      • proctozont
        • May 2007
        I'm using Zabbix 1.3.8 and both FreeBSD 5.5 and 6.2
        At configure stage I get mass problems.
        On FreeBSD 5.5 and FreeBSD 6.2 problems was different.
        Looks like Zabbix has problems with FreeBSD.
        1.4 configure looks different, but similar condition can be found at line 10033.
        Zabbix 1.3.8 confugure net-snmp section: line 9959
        		[B][COLOR=Red]_libnetsnmp_libdir="`$_libnetsnmp_config --libs`"[/COLOR][/B]
        		_full_libnetsnmp_cflags="`$_libnetsnmp_config --cflags`"
        		for i in $_full_libnetsnmp_cflags; do
        			case $i in
        				-I*)
        					SNMP_CFLAGS="$SNMP_CFLAGS $i"
        			esac
        		done
        		_full_libnetsnmp_libs="`$_libnetsnmp_config --libs` -lcrypto"
        		for i in $_full_libnetsnmp_libs; do
        			case $i in
        				-L*)
        					[B][COLOR=DarkGreen]SNMP_LDFLAGS="${SNMP_LDFLAGS} ${_libnetsnmp_libdir}"[/COLOR][/B]
        			esac
        		done
        Zabbix 1.4 confugure net-snmp section:line 10033
        	if test -f $_libnetsnmp_config; then
        			case $i in
        				-I*)
        			esac
        		done
        			case $i in
        				-L*)
        					SNMP_LDFLAGS="${SNMP_LDFLAGS} $i"
        			esac
        		done
        In Zabbix 1.3.8 I add line marked red, but there was line I marked green, so I just guess that you maybe should fix it too. For me it helped, but absolutly no warranty that it can help with 1.4. Different problems was even betwen versions of FreeBSD.
        At FreeBSD 5.5 configure command was:
        ./configure \
        --prefix=/root/zabbix \
        --enable-server \
        --enable-agent \
        --with-mysql \
        --with-net-snmp \
        At FreeBSD 6.2 configure command was:
        ./configure \
        --prefix=/usr/local \
        --sysconfdir=/usr/local/etc \
        --enable-server \
        --enable-agent \
        --with-mysql \
        --with-net-snmp
        Because on FreeBSD 5.5 I got CURL Error as your.
        I didn't compile 1.4, so if you will successfully compile it please write that you did.
        • andrew.p
          • Jun 2007
          proctozont,
          Thank you! I made a change on line 10050:
          changed this
          			case $i in
          				-L*)
          			esac
          		done
          to
          			case $i in
          				-L*)
          			esac
          		done
          And it worked.
          • treyh
            • May 2007
            • 64
            freebsd 6.2
            I have tried your suggestions and I still get this using the modified configure and the original:
            checking for curl-config... /usr/local/lib
            I did this to fix it:
            cp /usr/local/lib/libcurl* /usr/lib/
            I then received: Not found NET-SNMP library
            always fun stuff
            • andrew.p
              • Jun 2007
              treyh,
              what did your configure command look like?
              • treyh
                • May 2007
                • 64
                hey
                I've tried:
                ./configure --enable-server --with-net-snmp --with-mysql --with-libcurl --prefix=/var/apps/zabbix14
                ./configure --enable-server --with-net-snmp=/usr/local/ --with-mysql --with-libcurl --prefix=/var/apps/zabbix14
                ./configure --enable-server --with-net-snmp=/usr/local/bin/ --with-mysql --with-libcurl --prefix=/var/apps/zabbix14
                If i specify /usr/local or /usr/local/bin with libcurl it dies there, but it works when blank
                • treyh
                  • May 2007
                  • 64
                  config.log
                  I also saw this in config.log
                  configure:10010: found /usr/local/bin/net-snmp-config
                  configure:10023: result: /usr/local/bin/net-snmp-config
                  configure:10159: checking for main in -lnetsnmp
                  configure:10188: gcc -o conftest -g -O2 -I/usr/local/include/mysql -fno-strict-aliasing -pipe -I/usr/local/include -L/usr/local/lib/mysql -L/
                  usr/local/lib conftest.c -lnetsnmp -lkvm -lm -lmysqlclient -lcurl >&5
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_DigestInit'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_DigestFinal'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_DigestFinal_ex'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `AES_set_encrypt_key'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_md5'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `HMAC'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_MD_CTX_cleanup'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `SSLeay'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_sha1'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_MD_CTX_init'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `EVP_DigestUpdate'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `RAND_bytes'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `DES_cbc_encrypt'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `DES_ncbc_encrypt'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `DES_key_sched'
                  /usr/local/lib/libnetsnmp.so: undefined reference to `AES_cfb128_encrypt'
                  configure:10194: $? = 1
                  • proctozont
                    • May 2007
                    you should add line
                    and fix
                    to
                    See previous posts to see where to place this lines.
                    • treyh
                      • May 2007
                      • 64
                      fixed
                      thank you very very much, that worked
                      I also did a replace in vi like this, in case there was more than one reference:
                      vi configure
                      :%s/SNMP_LDFLAGS="${SNMP_LDFLAGS} $i"/SNMP_LDFLAGS="${SNMP_LDFLAGS} ${_libnetsnmp_libdir}"/g
                      • FrankTM
                        • Jun 2007
                        • 10
                        i used this thread to fix this on zabbix current nightly snapshots (to become 1.4.7)
                        i've added the patch as attachment to this post
                        i've used the following configure command:
                        ./configure --enable-server --enable-agent --with-mysql --with-net-snmp=/usr/local/bin/net-snmp-config
