How setup dependencies in Zabbix 1.4
  • seruas
    • Jun 2008
    I want to setup a pooling dependencies in Zabbix 1.4 if the host is down (ping failed/time out) Zabbix will stop any further/other checks like service checks or SNMP (because if the host is down no point to do any other checks so all other checks will depend on ping request = succeed.
    How I can do that in Zabbix?
    Regards,
    Sergio
  • just2blue4u
    • Apr 2006
    • 347
    in configuration/triggers click on that trigger, then in line "new dependency" click [select]
    next, select the trigger it should depend on, then click [add], [save]
    done.
    Where's the problem?
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
    • seruas
      • Jun 2008
      pooling data
      Hi just2blue4u,
      this is for triggers but what I want is something that stops Zabbix continue pooling data from a dead/down device stop querying the host.
      Thanks,
      Sergio
      • nelsonab
        • Sep 2006
        • 1233
        Originally posted by seruas
        Hi just2blue4u,
        Thanks,
        Sergio
        Unfortunately that is something you cannot do. I can see both sides on wanting to add a feature like that, but I don't think adding it would be a good idea. It would add another layer of complexity to the code and may have some unintended side effects/bugs down the road. I'm all about the simple. :-)
        RHCE, author of zbxapi
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I am not happy about implementing this. Actually I see little sense as ZABBIX "stops" (checks less frequently and the intervals are configurable!) monitoring of a device in case the device is not available. Why complicate things?
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • xs-
            • Dec 2007
            • 393
            Agreed, why would you want to stop item data collection. Item data and triggers are two seperate things.
            I do like the idea that (perhaps as a trigger option or something) if a host is down, all other host triggers go quiet.
            @devs: how about this: add a trigger boolean (checkbox or so) which indicates that this trigger is a 'host down' thing. If such a trigger is active, all other triggers go quiet.
            If a host has more than one of these 'flagged' triggers, any one of these triggers in true state will flagg the host as down and all other host triggers go quiet.
