Help adding switches
  • velosprinter
    • Jul 2008
    • 19
    I have been going crazy trying to get the right configuration for simple checks on switches and just can't figure out what is missing. I currently have 16 Windows servers and 3 Linux servers that monitor perfectly. However they all have agents.
    I have several dozen switches that I would like to ping check to see that they are alive. More information would be good but small steps for now.
    I can ping the switches without problem from the Zabbix server.
    The problem seems to be in adding the host.
    I put in the Name, IP, connect to:IP, and zero (0) as the port. I have also tried ports 22, 23, 25, 161, 1993, 10050 but no luck.
    Under Hosts it keeps coming back as:
    Availability: Not available
    Error: Timeout while connecting to [IP of my switch:161]
    Port was set to 0
    Log errors:
      1478:20080723:072538 Timeout while answering request
      1477:20080723:072538 Timeout while connecting to [***.**.129.21:161]                          1477:20080723:072538 Host [ 5th SW]: first network error, wait for 15 seconds
      1477:20080723:072538 Parameter [Host_Infomation] will be checked after 300 seconds on host [ 5th SW]
      1479:20080723:072538 Timeout while answering request                                          1475:20080723:072538 Timeout while answering request
      1476:20080723:072539 Timeout while answering request                                          1478:20080723:072539 Timeout while connecting to [***.**.129.21:161]
      1478:20080723:072539 Host [5th SW]: first network error, wait for 15 seconds              1478:20080723:072539 Parameter [Uptime] will be checked after 120 seconds on host [5th S
    W]        1479:20080723:072539 Timeout while connecting to [***.**.129.21:161]
      1479:20080723:072539 Host [ 5th SW]: first network error, wait for 15 seconds              1479:20080723:072539 Parameter [Inside_ifInBytes] will be checked after 240 seconds on host
    [5th SW]        1475:20080723:072539 Timeout while connecting to [***.**.129.21:161]
      1475:20080723:072539 Host [5th SW]: first network error, wait for 15 seconds              1475:20080723:072539 Parameter [Connections] will be checked after 240 seconds on host [
    5th SW]        1476:20080723:072540 Timeout while connecting to [***.**.129.21:161]
      1476:20080723:072540 Host [5th SW]: first network error, wait for 15 seconds              1476:20080723:072540 Parameter [FreeProcMem] will be checked after 240 seconds on host [
    5th SW]        1499:20080723:072603 Timeout while answering request
      1499:20080723:072604 Timeout while connecting to [***.**.129.21:161]
    If I can get this working the trigger would be:
    {5th SW:icmpping.last(0)}=0
    Thank you in advance for your help.
  • cristhiano
    • Nov 2007
    • 48
    Try:
    nmap -sU -p 161 ip_of_switch
    and see if port 161 is up. If not, the snmp server of switch not enable.
    Can you do:
    snmpwalk -c name_your_community -v 1 ip_of_switch
    If not, name of SNMP community is wrong.
    • troffasky
      • Jul 2008
      • 634
      What template are you linking the host to when creating it? When I want a simple ping check, I use the Template_Standalone, and uncheck everything except ICMP.
      • velosprinter
        • Jul 2008
        • 19
        Ok I added
        snmp community public RO
        to the switch config and the connection is made and some data comes in from the switch.
        Hosts says Monitored / Available
        Available Free Processor Memory 25 Jul 14:39:55 1.34 Gb +37.38 Kb
        Host_Infomation 25 Jul 14:25:26 Cisco IOS Software, ... -
        Outside ifInBytes 25 Jul 14:40:00 4.90 Kb +164 b
        Outside ifOutBytes 25 Jul 14:40:02 165.73 b +94.13 b
        Ping Check 25 Jul 14:40:31 0 -
        Uptime 25 Jul 14:40:35 1y1m7d4h10m14s +32s
        However, no ping
        Yes I get an alarm because "Ping Check 25 Jul 14:40:31 0"
        gives a ton of data but this seems most relevent:
        SNMPv2-MIB::snmpInPkts.0 = Counter32: 2547
        SNMPv2-MIB::snmpOutPkts.0 = Counter32: 2547
        SNMPv2-MIB::snmpInBadVersions.0 = Counter32: 0
        SNMPv2-MIB::snmpInBadCommunityNames.0 = Counter32: 0
        SNMPv2-MIB::snmpInBadCommunityUses.0 = Counter32: 0
        SNMPv2-MIB::snmpInASNParseErrs.0 = Counter32: 0
        SNMPv2-MIB::snmpInTooBigs.0 = Counter32: 0
        SNMPv2-MIB::snmpInNoSuchNames.0 = Counter32: 0
        SNMPv2-MIB::snmpInBadValues.0 = Counter32: 0
        SNMPv2-MIB::snmpInReadOnlys.0 = Counter32: 0
        SNMPv2-MIB::snmpInGenErrs.0 = Counter32: 0
        SNMPv2-MIB::snmpInTotalReqVars.0 = Counter32: 0
        SNMPv2-MIB::snmpInTotalSetVars.0 = Counter32: 0
        SNMPv2-MIB::snmpInGetRequests.0 = Counter32: 56
        SNMPv2-MIB::snmpInGetNexts.0 = Counter32: 2505
        SNMPv2-MIB::snmpInSetRequests.0 = Counter32: 0
        SNMPv2-MIB::snmpInGetResponses.0 = Counter32: 0
        SNMPv2-MIB::snmpInTraps.0 = Counter32: 0
        SNMPv2-MIB::snmpOutTooBigs.0 = Counter32: 0
        SNMPv2-MIB::snmpOutNoSuchNames.0 = Counter32: 1
        SNMPv2-MIB::snmpOutBadValues.0 = Counter32: 0
        SNMPv2-MIB::snmpOutGenErrs.0 = Counter32: 0
        SNMPv2-MIB::snmpOutGetRequests.0 = Counter32: 0
        SNMPv2-MIB::snmpOutGetNexts.0 = Counter32: 0
        SNMPv2-MIB::snmpOutSetRequests.0 = Counter32: 0
        SNMPv2-MIB::snmpOutGetResponses.0 = Counter32: 2571
        SNMPv2-MIB::snmpOutTraps.0 = Counter32: 0
        SNMPv2-MIB::snmpEnableAuthenTraps.0 = INTEGER: disabled(2)
        SNMPv2-MIB::snmpSilentDrops.0 = Counter32: 0
        SNMPv2-MIB::snmpProxyDrops.0 = Counter32: 0
        Any ideas on notifying if the switch is down?
        • velosprinter
          • Jul 2008
          • 19
          Solved!!!
          I wrote a guide on how to do this in the Cookbook section:
