NetApp Filer
  • cjwallace
    • Sep 2008
    • 126
    NetApp Filer
    Guys.
    I have downloaded the NetApp Filer xml file from the WIKI (Thanks very much to the guy who posted it up)
    The problem is i have set up and a new host provided all the details and then linked the host to the NetApp template but after 60 minutes my host is still not showing as being monitored.
    Any ideas what i have done wrong?
    Does anyone have any documentation on this?
    Thanks in advance
  • nelsonab
    • Sep 2006
    • 1233
    My first thought is can you do an SNMP walk on the Filer from the Zabbix server using the same credentials?
    Once you've verified that then we can be confident it's not a network issue.
    RHCE, author of zbxapi
    • cjwallace
      • Sep 2008
      • 126
      Thanks mate for the reply. Can you confirm the command i need to run please?
      I used
      snmpwalk -c public IP ADDRESS HERE
      to which i get a snmpwalk: timeout
      Thanks for any help you can give
      Craig
      • cjwallace
        • Sep 2008
        • 126
        Hello mate.
        if i use the following command
        snmpwalk -v1 -c public 10.10.100.10
        Then it returns a whole load of information. So any ideas as to why everything is UNKNOWN in the zabbix console?
        Thanks in adavnce
        • cjwallace
          • Sep 2008
          • 126
          Also in the .xml file is
          <?xml version="1.0"?>
          <zabbix_export version="1.0" date="11.11.07" time="10.54">
          <hosts>
          <host name="Template NetApp">
          <ip>0.0.0.0</ip>
          <port>10050</port>
          <status>3</status>
          Do i need to put something in the IP line or is that correct being 0.0.0.0?
          Thanks in advance
          • cjwallace
            • Sep 2008
            • 126
            Just some more information.
            I had a look at some of the commnds the .xml files will run and i copied them over to the Zabbix console and run them for example
            snmpwalk -v1 -c public IP ADDRESS HERE .1.3.6.1.4.1.789.1.7.1.8.0
            Which returned the Domain Controller the NetApp filer was connected to so it looks like my SNMP is setup right. In the Zabbix console everything is just displaying UNKNOWN even simple ping?
            Just at a loss right now as to what to check next
            Thanks in advance
            • cjwallace
              • Sep 2008
              • 126
              Doh.
              It would seem my zabbix_server had stopped. As soon as i started it again loads of information started to flow through.
              I am sure i am going to have some further questions.
              Cheers
              Craig
