Monitoring remote sites(TRAPPER?)
  • gospodin.horoshiy
    • Sep 2008
    • 272
    Hi.
    I've just installed Zabbix on my VMWare Ubuntu(testing) , think it's great, but I have a way to go to configure it properly for my needs.
    Thing is, we have a bunch of remote sites, which have NAT, firewalls, and some of those sites don't even have static Internet IP address.
    So, my question is, is it possible to monitor servers and workstations there by Zabbix server( which is accessible from the Internet) using only one way connections from Agents to Server , (I think that will be Trapper,)?
    If not, are there any good workarounds ?
    Thank You very much
    Zbx 2.0.4 on Debian and MYSQL5 on Ubuntu Server 64bit 8.04,
    200+ Win Agents, 50+ Linux Agents, 150+ Network Devices
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You may consider using active checks. In this case agent will connect to ZABBIX server. No connections from the server side will ever be initiated!
    Use of ZABBIX Proxy is the best alternative for monitoring of remote locations having more than 10-100 devices. ZABBIX Proxy would be installed in the remote network, collect performance and availability data from the locations and forward everything to the server.
    We guarantee extremely easy maintenance and good sleep!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • gospodin.horoshiy
      • Sep 2008
      • 272
      Thanks for quick reply, now I know that everything is possible) Cheers
      • gospodin.horoshiy
        • Sep 2008
        • 272
        What IP address should I configure when configuring Host(active checks only) in Zabbix webconsole? Leave it 0.0.0.0? Thanks
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          The IP address is optional, leave it empty.
          Alexei Vladishev
          My Twitter
          • gospodin.horoshiy
            • Sep 2008
            • 272
            Alexei, I'm getting an error in this case: "Warning. Field [ip] is not IP"
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              It means that the value you entered does not look like an IP address.
              Alexei Vladishev
              My Twitter
              • gospodin.horoshiy
                • Sep 2008
                • 272
                Sure, it does not, since the field is empty.
