Triggering Applications
  • vma
    • Nov 2008
    Is there a possibility to monitor all the applications with just one trigger?
    I'm monitoring a few windows services, which I put under the Application: Services.
    I'd like to monitor these services with a trigger like this:
    {<hostname>:service_state[<servicename>]. last( 0 ) }#0
    As I'm adding up to 10 or 20 services, different for every server, and they all need the same rule. I'm wondering if there is a possibility.
    I've looked over the forum but couldn't find anything who knew the solution or the answer.
  • bbrendon
    • Sep 2005
    • 873
    You can create a script that makes sure all services that are set to auto are running. I think there are examples online.
    Unofficial Zabbix Expert
    Blog, Corporate Site
