data usage per month
  • woger
    • Sep 2005
    • 56
    Hi there,
    I've set up snmp monitoring of a cisco switch, but now I want to know what each port uses per month on traffic. I thought that the monthly read of the ifInOctets and ifOutOctets and take their delta should do the trick, but will this give problems when the Octets counter is reset by the switch?
    Is there a more logical way to do this?
    Thanks,
    Roger
  • Tenzer
    • Nov 2007
    • 316
    You will have to check each entry in the database read from the switch, in order to find out how many times the counter has reset, and then calculate the data amount from that.
    • nelsonab
      • Sep 2006
      • 1233
      I've written a couple of scripts to perform this function on my own system. Right now I use it to generate weekly bandwidth reports for every port on one of our switches. If you would like a copy let me know and I'll clean it up a little bit for you and send it to you.
      RHCE, author of zbxapi
      • woger
        • Sep 2005
        • 56
        That would be great!
        Thanks,
        Roger
        • troffasky
          • Jul 2008
          • 639
          Yes please.
          • cosmobot
            • Aug 2009
            • 14
            Can you publish its anythere ?
            Perhaps in wiki?
            Thank
            • rekeds
              • Feb 2014
              • 21
              yeah, that would be great
