Son of a gun.
Another fping problem...
Thanks Rich...
Cant believe I didnt even try that...anyway it is now registering values on the graph. I did put "ms" as my units but I'm getting .09 as opposed to the 90ms that I would really like...
I tried removing ms as my units...no change.
Thanks for hanging in there!!
Colin.Comment
well, try setting custom multiplier to 1000.
i'm not sure it's the best solution, but it worksComment
It looks like there may be something to that. It's trying to use -S instead of -s for fping:
8275:20090326:140032 /usr/sbin/fping -S -c3 2>/dev/null </tmp/zabbix_server_8275.pinger
I'm not sure I know the exact syntax to replace the -S in the file but I've made a backup of the original so I'll tinker with it. My only problem is that my 1.6.1 server has the same thing in the .c file and it's working fine.
Here goes nothing!
KerryComment
Ok, I know it's poor form to reply to yourself, but maybe this will help you other guys. Stop the server, replace the -S with a -s, save the file, do a make install, then restart the server. When you do make install it will tell you "nothing to do" in most places, it will just have one small change to make.
That seems to do the trick, icmpping is now working fine. Icmppingsec doesn't seem to be working yet but I'm not using it right now so I'll tinker with that later.
Thanks for the tip on editing the .c file and running make again.
KerryComment
um, -S is using a patched fping feature - it sets source ip address. you could also remove source ip config parameter from server config file.Comment
Hi
I unpackaged the source RPM fping-2.4-1.b2.rf.src.rpm,
added the fping "-S" patch to the fping source
and repackaged it for i386 and amd64 archs but didn't test
it, yet.
I'm not sure where to put the RPMs, though.
My Website is still under construction.
If there is interest, please tell me.
Regards
Norbert.Comment
