zabbix & zimbra
  • jenifer1402
    • Apr 2009
    • 21
    zabbix & zimbra
    I have a Zabbix server already installed with Zabbix agent
    I have a Zimbra server already installed contains the following services:
    *zimbra-5.0.14
    *Bind9
    *openldap
    *mysql
    I want to supervise Zimbra and all there services is there someone has an idea on this subject!
    thanks
  • troffasky
    • Jul 2008
    • 639
    Look at the Linux server template and what it does to monitor services. Clone them and adjust the name of the process it looks at. Also, Zimbra has its own SNMP service.
    Zimbra have deleted that page unfortunately
    • Eddriks
      • Apr 2010
      • 22
      Hey jenifer1402 & everybody!
      (sorry for my bad english..i'm french )
      your thread interest me, I'm looking for advice / solution for monitoring zimbra with zabbix ( Zabbix 1.8.2 , Zimbra 6.06 ).
      have you find informations / solutions about this Jenifer1402 or any other persons .
      Thx!
      • troffasky
        • Jul 2008
        • 639
        What are you trying to monitor that isn't visible via Zimbra's SNMP service or the Zabbix agent?
        • Eddriks
          • Apr 2010
          • 22
          hello troffasky,
          I'm trying to monitor values like : number of spam/viruses - mail transit (In/Out), Connected client etc etc..
          I'dont think that I can get this with the Zabbix Agent ?
          There are this values in the zimbra interface, but I would like to get this in Zabbix ( all-in-one interfaces... . Is it possible ?
          Thx
          • nelsonab
            • Sep 2006
            • 1233
            Zimbra uses ClamAV and Spamassassin under the hood in the /opt/zimbra directory. There are likely some hooks in those tools which may allow you to gather the stats you are looking for. Be careful if you change any of the configuration files in the /opt/zimbra directory as they may be overwritten at any time by the Zimbra app along with the potential for very unintended side effects.
            RHCE, author of zbxapi
            • troffasky
              • Jul 2008
              • 639
              But he probably doesn't need to do any of that because Zimbra has an SNMP interface.
              • nelsonab
                • Sep 2006
                • 1233
                True, *if* the SNMP interface provides that data, if not, then you have to dig in yourself.
                • Eddriks
                  • Apr 2010
                  • 22
                  Hello everybody !
                  first of all thanks for your replies !
                  in fact... the SNMP Interface provide data... but not the data I'm looking for...
                  but, I've read that ZmStats ( monitoring tools of zimbra ) generate csv file with all the data I'm looking for! so , I think I'll parse these csv file with script and UserParameter to catch data that i want.
                  I'll write my feedback when I'll have finish this .
                  thanks you again !
                  best regard
                  • nelsonab
                    • Sep 2006
                    • 1233
                    That was my fear.
                    Good to hear!
                    • Datum
                      • Jul 2012
                      My company is working on an improved and more reliable solution for monitoring Zimbra with Zabbix using a custom template/script combination. (currently for Zabbix 1.8)
                      When we iron out a couple of bugs and have it working to the point that we are happy and don't receive false positives anymore, we'll be posting a tutorial and all files needed to make it all work.
                      Stay tuned, it's currently a work-in-progress.
                      • corsino
                        • Mar 2013
                        • 22
                        Zimbra Template
                        Do you have any news about the template/script?
                        • Datum
                          • Jul 2012
                          Unfortunately this project got stuck in the mud and forgotten for a while. We recently have gotten back into getting Zabbix set up across the board. So I'm sure I'll be resurrecting this project in the near future.
                          I'll be sure to post my progress.
                          • malayo
                            • Feb 2013
                            • 9
                            Datum, any updates on your zimbra monitoring project with zabbix?
