How to organize a multiple box cluster
  • jcesario
    • Apr 2009
    • 65
    I have 2 boxes. They are setup to share a bunch of HA services.
    The DNS is setup as such:
    box-1.example.com
    box-2.example.com
    box-ha.example.com
    The HA services only listen on the -ha address which is an IP that is failed back and forth between the boxes when necessarry
    I want to be able to monitor both boxes in the cluster for their OS level stuff. I want to have it so that that the HA services are monitored independently of the two boxes. Prefferably under a separate host names box-ha.example.com
    How would I do this in zabbix?
  • jcesario
    • Apr 2009
    • 65
    Bump! Still interested in figuring out best practice for this type of setup.
    • rue
      • May 2006
      • 43
      box-1.example.com
      box-2.example.com
      box-ha.example.com
      Well, create 3 hosts?
      No, seriously: Create two hosts for the OS-stuff and link them to appropriate templates and create one host for the HA-stuff... .
      cheers
      RĂ¼
      • bbrendon
        • Sep 2005
        • 873
        Also, linux HA has some scripts that report the status of the cluster. You can pipe those into zabbix as well to know if you're live but in failover mode, etc.
        Unofficial Zabbix Expert
        Blog, Corporate Site
