Host status deosn't work well ?
  • kiki_arch
    • Aug 2008
    • 17
    Hi all,
    I got a trigger on host status. When the server is on, no problem, the trigger is green. But when the server shutdown, the trigger is grey... not red ! Where does the problem come from ?
    Thanks,
    kiki_arch
  • kiki_arch
    • Aug 2008
    • 17
    No idea anyone ?
    • kiki_arch
      • Aug 2008
      • 17
      I really need help because I can't see when a server is down because the trigger doesn't work well...
      My trigger :
      {Alien:agent.ping. last( 0 ) }#1
      My item :
      agent.ping
      • Artturi
        • May 2006
        • 16
        This item is calculated by the server when a change occurs.
        Initial state is unknown so you force a change by yourself (I think a "stop, wait & start" of the zabbix service would help).
        Regards,
        • pesadilla
          • Nov 2006
          • 69
          i prefer .nodata
          • kiki_arch
            • Aug 2008
            • 17
            Artturi,
            Before this trigger was working well. since a time, it doesn't work well... By the way, however I've done you suggestion : to stop, wait & start the service but it don't answer to my problem.
            pesadilla,
            What do you mean with "I prefer .nodata" ? because when the server is down, the trigger is grey whith th value : "nodata"... you mean that i must base my trigger on this string ?
            • IvanG
              • Aug 2008
              • 12
              I have a similar problem. Almost 10 of 30 servers has the alarm "Server {HOSTNAME} is unreachable" on the dashboard on grey status, instead of green / red status. I don't know why those items are not updated.
              Thanks!
              • IvanG
                • Aug 2008
                • 12
                An update: 1 of the monitored servers is working well... server is down, host unreachable status is red and the other data is grey. I think this is the correct work of Zabbix, but I'm trying to find wheter is the error on the others
