i'm currently testing the logs monitoring feature of zabbix. I've made a text file where I add some new lines with :
echo 'content' >> /path/file.log
Then, I've made an item to catch some special lines.
I've seen I can use :
log[/path/file.log,ABC] : to match all line with ABC
log[/path/file.log,A[1-5]B] : to match all line with A1B, A2B, A3B, A4B or A5B.
So my question is : is there a documentation where a can find all the syntaxes awailable in the "pattern" ?
For example, I would like to match : AdfdfdfqdsB and AhhhhhkjB.
I've put : log[/path/file.log,A[a-z]*B], but it's not ok... I think it's not the right syntax...
Thanks in advance.
Thanks in advance.
