snmp SET with zabbix
  • wpervaiz
    • May 2009
    • 30
    so i can get snmp values using the oid... but is there a way that i can SET a value using snmp oid ??
    that would be so awesome!
    Thanks!
  • nelsonab
    • Sep 2006
    • 1233
    Not directly.
    Probably the best way to go about doing it would be as part of an external action which is tied to a trigger. Trigger activates, external action runs (script) and the oid is set. It may not be pretty but it's the best you can do for now within Zabbix.
    RHCE, author of zbxapi
