Hi all,
I'm managing multiple mailservers using Zabbix, of which one is not reachable via a normal network connection. The only way to monitor this server is by setting up an STunnel connection and using active checks. Since all items are configured in a template, I can't apply the template to the special STunnel service because it needs to use active checks.
Is it somehow possible to configure the "active agent" flag per instance of a template, in stead of configuring it inside the template itself? That way, I would be able to use the same template for all mailservers and configure a few items for using the "active agent" at the instance of the template.
Any suggestions on this?
