Zabbix with httpd.conf
  • Mumtaz Shaikh
    • Jul 2009
    Dear Frineds,
    I have installed zabbix on RHEL 5.
    I have completed the installation of the zabbix server and agent on the server
    created the zabbix DB in mysql and modifed the db.inc.php file
    but i don't have nay idea about what to put in httpd.conf file for the zabbix webpage.
    I had copied all .php file to my DocumentRoot /var/www/html
    cp -r /tmp/zabbix-1.6.5/frontends/php/* /var/www/html
    what sholud i put in DirectoryIndex paramemter of the httpd.conf file
    Thanks in advance,
    Mumtaz Shaikh
    RHCE/IBM AIX Certified
  • MrKen
    • Oct 2008
    • 652
    Not sure that you need to edit db.inc.php, more likely you mean zabbix.conf.php
    Which, on your system, is probably in /var/www/html/conf/ or maybe /var/www/html/zabbix/conf
    that will tell zabbix your db details.
    Shouldn't be necessary to edit httpd.conf
    Hope that helps.
    MrKen
