Support Ticketing Systems
  • Vince
    • Jul 2009
    Hi Zabbix admins,
    I was wondering if anyone has done work integrating zabbix with a ticketing system? I know zabbix has it's own internal system for commenting on device events, but we are looking for a more customer facing side of this ticketing / support system which could also accept general support questions from clients as well as device down events from zabbix.
    I came across Tender App:
    This has a lot of the functionality that I was going for and also has an API for potentially integrating with monitoring software like zabbix.
    Has anyone used Tender, or another ticketing system that you like and that integrates well with zabbix?
    Thanks!
  • richlv
    • Oct 2005
    • 3112
    that depends on what you mean by integrating. usually people want to open tickets for high severity events from within zabbix - and that is usually trivially done by using email interfaces in the ticketing systems.
    you can also use custom alertscript to call just about anything.
    with the numeric severity macro you can even open tickets with the desired severity
    • low10sws6
      • Oct 2008
      • 44
      has anyone done any of this?
      • richlv
        • Oct 2005
        • 3112
        well, yes, of course. most often used message is to simply format email alerts for a particular user in whatever format ticketing system accepts, then just pass them to the ticketing system.
        • nelsonab
          • Sep 2006
          • 1233
          With the new Zabbix API and an API interface to a ticketing system making the glue for this becomes easier.
          RHCE, author of zbxapi
          • Vince
            • Jul 2009
            What kind of ticketing systems is everyone using? Custom inhouse systems, other open source software, hosted service? Integrated with a CRM?
            • mfburgo
              • Apr 2007
              • 12
              Currently we use GLPI and OCSInventory. Passing tickets via email to ba assigned by Management
              • nelsonab
                • Sep 2006
                • 1233
                At one client site they use Trac for all of their IT tickets. In time it would be neat to see some integration with trac and zabbix.
                • nms_user
                  • Feb 2009
                  • 43
                  We use OTRS as ticketing system; the actions in Zabbix are configured to send an email to OTRS.
                  In OTRS the Postmaster-filter is configured to parse the mail for several strings which Zabbix includes in the action ('Contact' as definition for the correct team/queue, 'severity' as ticket-priority, ...).
                  So we get a ticket which is located in the right queue and with the appropriate priority.
                  One bad side of this construction: It's a one way thing - the event isn't automatically handled in Zabbix (e.g. no acknowledge). But with the api one can handle this easily, too.
                  • troffasky
                    • Jul 2008
                    • 639
                    Using Trac here, mainly because it integrates with RANCID [for Cisco config management] and we can use the Wiki component as a knowledge base. Get far too many false positives to want automated ticket raising from Zabbix alerts.
                    • nickfarrell
                      • May 2008
                      We've integrated it with our own in-house ticketing system, basically it watches the triggers table and uses the 'comments' field to log the ticket number it has allocated to the ticket.
                      So every minute we check the triggers, open new tickets where required.
                      If a trigger has been closed off (i.e. the problem resolved itself) then our script notes in the ticket that this has happened, but leaves the ticket open so that an engineer can review it.
                      It works pretty well, and reliably - we've been using it for about a year now.
                      End result - after 3 minutes a ticket is automatically opened, and notes are put in automatically when Zabbix reckons the problem is resolved.
                      • tbogdan
                        • Sep 2010
                        zabbix with redmine, zabbix send mail to a mailbox monitored by redmine, these emails contain something like this:
                        --- cut ---
                        Project: project-name{ex name-of-client}
                        Tracker: type-of-tracker{ex monitoring}
                        Service - {TRIGGER.NAME}: {STATUS}
                        Date/Time - {DATE} / {TIME}
                        Event age - {EVENT.AGE}
                        ItemName - {ITEM.NAME}
                        LastValue - {ITEM.LASTVALUE}
                        -- end cut ---
                        • johnhailstone
                          • Feb 2010
                          otrs to zabbix setup
                          Hi nickfarrell
                          We have setup an inbox that zabbix can send actions out to that then generates otrs tickets on the postmaster filter rules.
                          We however are having big issues getting zabbix to update tickets afterwards with what zabbix reports next, these are being raised as new tickets.
                          what rules are you using on postmaster filter or what script are you running that sinks the two actions together?
                          would massively appreciate any help you can give on this
                          John.
                          • shreya
                            • Apr 2013
                            OTRS and Zabbix integration
                            Can u please give me details for how to integrate OTRS with Zabbix..
                            • neilb
                              • Jan 2013
                              • 33
                              #15
                              Hmm, this is quite timely, i'm also seeking a new ticket/crm system which can have bi-directional traffic between it & the monitoring system.
                              be interested to hear upon any solutions.
                              N.
