I have problems when inserting the item of icmpping and icmppingseg
  • daniel_lugo
    • Nov 2009
    • 14
    Hello
    I need help only gives me information on some occasions 0 and changing the parameters of the item to floating leaves eset message: / usr / sbin / fping: [2] No such file or directory
    Searching google it recommended to install fping install the monitoring server and every computer that I monitor this with the purpose of solving the problem, but even I can not give solutions also check the file and check the route zabbix_agentd.conf: FpingLocation = / usr / bin / fping probe by editing one fpingLocation = / usr/sbin/fping6 and nothing, also copy the file / usr / bin / fping to / usr / sbin / and changing the name but I turned fping6
    I set the item as follows:
    ITEM icmpping
    Description: Ping
    Type: simple check
    Key: icmpping
    Type of information: number (float)
    Units:
    Use multiplier: Do not use
    Update interval (in sec): 30
    Flexible intervals (sec) intervals not flexible
    New flexible interval Delay Period
    Status: Active
    Store value: As is
    Show map throw value: As is
    New application
    Applications:
    ITEM icmp icmppingsec
    Description: Pingseg
    Type: simple check
    Key: icmppingsec
    Units:
    Status: Active
    Store value: As is
    New application
    Applications:
    I hope I can help solve the problem ...
    These items grafiacar the need for the Round Trip Times
    Thank you very much and I thank comments
