I'm experimenting with Zabbix on Linux and having some difficulties with triggers on vfs.fs.size pused.
I would like a trigger when a filesystem is filled for 80%.
Now I get this trigger when a df shows 85% because of the 5% reserved blocks.
Is there a workaround or patch so vfs.fs.size pused reads the same value as a df, ignoring the reserved blocks?
Thanx
Thanx
