Dashboard - Disaster High Average Warning Information Not classified
  • swardell
    • Dec 2009
    • 13
    I want to change the headings
    Disaster
    High
    Average
    Warning
    Information
    Not classified
    to something that means more and (imho) follows a more progressive scale
    Disaster
    High
    Medium
    Low
    Warning
    Information
    Not classified
    for example
    Short of hacking the php is there a way to do this? It strikes me this should be a value map but I cant seem to see it if it is?
  • igor
    ZABBIX Support Specialist
    • Mar 2009
    • 40
    Hi!
    For priority definition of the trigger is used field "priority" in the table "triggers". There are stored integer values from 0 (Not classified) to 5 (Disaster). Definition of this priorities is somewhere in the frontend files, you need to search it on your own.
    • gessel
      • Mar 2017
      • 24
      If anyone finds this looking for how to customize trigger severity, here's how to do it:
      • tcilmo
        • Nov 2016
        • 122
        You can have custom severity names, but manual translation is required.
