1.6 settings exporting to 1.8
  • saitoh
    • Aug 2009
    • 10
    I am looking to replace my hardware that is running 1.6, can I import the settings from 1.6 into a 1.8 build?
  • Jason
    • Nov 2007
    • 431
    You can also export your database, import it into your new 1.8 server and then run the database upgrade patch (see the manual) and then carry on on 1.8 exactly as you were on 1.6
    • saitoh
      • Aug 2009
      • 10
      excellent, many thanks
