Citrix xenserver 5.5
  • rboersma
    • Jan 2010
    • 29
    Hi all,
    I'm trying to compile the zabbix_agentd for Citrix xenserver 5.5 using the SDK VM, which you can download here:
    After compiling i'm trying to manually start the zabbix agent:
    [root@servername init.d]# ./zabbix-agentd start
    /usr/local/sbin/zabbix-agentd not installed
    which is there and executable:
    [root@servername sbin]# ls
    zabbix_agent zabbix_agentd
    when starting it from sbin:
    [root@servername sbin]# zabbix_agent
    zabbix_agent [2992]: Cannot open config file [/etc/zabbix/zabbix_agent.conf] [No such file or directory].
    Any suggestions? Also zabbix only wants to run as a user, but with citrix xenserver everything runs as root.
    best regards,
    Ruud
  • Firm
    • Dec 2009
    • 342
    What does 'ls -l /usr/local/sbin/zabbix-agentd' show? It seems that /etc/zabbix/zabbix_agent.conf doesn't exist.
    • rboersma
      • Jan 2010
      • 29
      that shows:
      ls: /usr/local/sbin/zabbix-agentd: No such file or directory
      but it is there:
      [root@server zabbix]# cd /usr/local/sbin
      [root@server sbin]# ls
      [root@server sbin]#
      Same counts for /etc/zabbix/zabbix_agentd.conf. The file is present.
      • elvar
        • Feb 2008
        • 226
        Originally posted by rboersma
        Hi all,
        best regards,
        Ruud
        Very excited to see someone else wanting to put a zabbix agent on Xenserver 5.5. I tried doing this too but the Xenserver 5.5 environment seems to be very controlled and restricted. I'm eager to see if you get this going without breaking anything.
        • elvar
          • Feb 2008
          • 226
          that shows:
          but it is there:
          [root@server sbin]#
          Did you try running specifying the config file manually?
          SYNOPSIS
          zabbix_agentd [-hpV] [-c config-file ] [-t metric]
          • deejay24
            • Dec 2009
            i am using the zabbix-agent on my xenserver 5.5 system and it worked well.
            Have you created an zabbix user ?
            Is the directory / config file existent ?
            Are the user rights for the files correct ?
            And later on ...
            You have to edit some things for the firewall of the server.
            In a few hours i can post a complete install instruction for installing the zabbix agent on xenserver.
            best regards,
            deejay24
            • elvar
              • Feb 2008
              • 226
              And later on ...
              best regards,
              deejay24
              That would be greatly appreciated!
              • deejay24
                • Dec 2009
                HI,
                here are some install instructions
                ... my logfiles for zabbix are in /var/log/zabbix ;-)
                you have to use a special zabbix agent !!
                (bulid fo xenserver, i use a self compiled 1.4.4)
                copy zabbix agent files to /usr/local/sbin
                (zabbix_agent, zabbix_agentd, azbbix_sender)
                mkdir /etc/zabbix
                mkdir /var/log/zabbix
                copy existing zabbix_agent.conf to /etc/zabbix/
                copy existing init script to /etc/initd./
                useradd zabbix
                chown zabbix /var/log/zabbix
                chown zabbix /usr/local/sbin/zabbix*
                edit you init script
                edit the runlevel for your script via
                chkconfig --level 2345 zabbix-agentd on
                edit xenserver firewall via
                nano /etc/sysconfig/iptables
                add the line
                -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 10050 -j ACCEPT
                save this and restat the iptables service
                service iptables restart
                edit you zabbix_agentd.conf
                nano /etc/zabbix/zabbix_agentd.conf
                and last but not leased start your agent
                /etc/init.d/zabbix_agentd start
                and check via
                /tail -f /var/log/zabbix/zabbix_agentd.log
                So i hope this will help a bit.
                deejay24
                • rboersma
                  • Jan 2010
                  • 29
                  Thanks,
                  This is what i did so far:
                  I compiled the 1.8.1 version using the Xenserver 5.5 SDK virtual machine.
                  1. copy the src packages with winscp
                  2. log in as root on the sdk vm
                  3. untar the packages
                  4. ./configure --enable-agent --enable-static
                  5. make install
                  6. zabbix_agent and zabbix_agentd are created in /usr/local/sbin
                  7. copy the agents from the sdk box to the windows box and then to the xenserver 5.5 machine in usr/local/sbin
                  8. useradd zabbix on xenserver 5.5 no pwd supplied
                  9. chmod 755 zabbix_agent*
                  10. chown zabbix zabbix_agent*
                  11. mkdir /etc/zabbix
                  12 chown zabbix /etc/zabbix
                  13. copy zabbix_agentd.conf to /etc/zabbix
                  14. chown zabbix /etc/zabbix/zabbix-agentd.conf
                  15. mkdir /var/log/zabbix
                  16. chown zabbix /var/log/zabbix
                  17. copy existing init script to /etc/init.d
                  18 changed ZABBIX_AGENTD_BIN=/usr/sbin/zabbix-agentd in init script to ZABBIX_AGENTD_BIN=/usr/local/sbin/zabbix-agentd
                  19. edited /etc/sysconfig/iptables with line -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 10050 -j ACCEPT
                  20 restart iptables with "service iptables restart"
                  manually start agentd logged on as root:
                  ./zabbix_agentd start
                  The file /usr/local/sbin/zabbix_agentd is there. Have you got any idea what i'm doing wrong?
                  EDIT: totally missed the post made by Elvar. If agent started from /usr/local/sbin (so not using the init script) and set the -c /etc/zabbix/zabbix_agentd.conf it tried to start the agent.
                  Logfiles says "Cannot create PID file [/var/run/zabbix/zabbix_agentd.pid] [No such file or directory]"
                  So I created "mkdir /var/run/zabbix" and "chown zabbix /var/run/zabbix"
                  The agent actually starts now. Any idea why it cannot find the config on it's own?
                  And I'm not familiar with auto starting the agent at boot. how do I do that?
                  • deejay24
                    • Dec 2009
                    here a bit of my /etc/init.d/zabbix-agentd
                    #!/bin/bash
                    # Zabbix Agentd for Xen Server
                    # chkconfig: - 50 50
                    # description: Zabbix Agentd
                    # processname: /usr/local/sbin/zabbix_agentd
                    # config: /etc/zabbix/zabbix_agentd.conf
                    # pidfile:
                    # source function library
                    . /etc/init.d/functions
                    RETVAL=0
                    prog="zabbix_agentd"
                    start() {
                    echo -n $"Starting $prog: "
                    if [ $UID -ne 0 ]; then
                    RETVAL=1
                    failure
                    else
                    daemon /usr/local/sbin/zabbix_agentd
                    RETVAL=$?
                    [ $RETVAL -eq 0 ] && touch /var/lock/subsys/zabbix_agentd
                    fi;
                    echo
                    return $RETVAL
                    and in zabbix_agentd.conf
                    # Name of PID file
                    PidFile=/var/tmp/zabbix_agentd.pid
                    ... this works for me ...
                    • rboersma
                      • Jan 2010
                      • 29
                      files
                      I want toattached the files that are needed to run the zabbix agent on xenserver 5.5, but the forum does not allow it. Please let me no where to send them.
                      The files are compiled on the xenserver 5.5 SDK virtual machine.
                      I have tested the agent succesfully.
                      Ruud Boersma
                      • rboersma
                        • Jan 2010
                        • 29
                        One last thing.
                        everything seems to work fine for now except one strange thing.
                        The zabbix hosts commmunicates with the agent and sees what version of the agent is running. But it also tells me it cannot communicate with the agent.
                        Number of running processes zabbix-agentd 0 (is red error on host)
                        Version of zabbix-agent(d) running 1.8.1 ( it sees this version info and all other info that is within the default linux template)
                        Any suggestions?
                        • cybernijntje
                          • Sep 2008
                          • 16
                          Our zabbix XenServer installation
                          Copy the zabbix client (X:\Install\Apps\Linux\Zabbix_client\zabbix_client .tar.gz)
                          to the /tmp directory of the Xenhost. Then execute the following commands:
                          svr-zen5[xx] # cd /tmp
                          svr-zen5[xx] # tar -zxvf zabbix_client.tar.gz
                          svr-zen5[xx] # mkdir –p /usr/local/zabbix/bin
                          svr-zen5[xx] # cd zabbix
                          svr-zen5[xx] # mv zabbix_agentd /usr/local/zabbix/bin/
                          svr-zen5[xx] # mkdir /etc/zabbix
                          svr-zen5[xx] # mv zabbix_agentd.conf /etc/zabbix/
                          svr-zen5[xx] # mv zabbix_agent /etc/rc.d/init.d/
                          svr-zen5[xx] # cp /etc/zabbix/zabbix_agentd.conf \
                          /etc/zabbix/zabbix_agentd.conf.orig
                          svr-zen5[xx] # vi /etc/zabbix/zabbix_agentd.conf
                          # This is config file for zabbix_agentd
                          # To get more information about ZABBIX, go http://www.zabbix.com
                          # List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
                          # No spaces allowed. First entry is used for sending active checks.
                          # Note that hostnames must resolve hostname->IP address and
                          # IP address->hostname.
                          Server=10.85.207.60
                          # Server port for sending active checks
                          ServerPort=10051
                          # Unique hostname. Required for active checks.
                          Hostname=SVR-Zen[xx]
                          # Disable active checks. The agent will work in passive mode listening server.
                          DisableActive=1
                          # Specifies debug level
                          # 0 - debug is not created
                          # 1 - critical information
                          # 2 - error information
                          # 3 - warnings (default)
                          # 4 - for debugging (produces lots of information)
                          DebugLevel=1
                          UserParameter=xe.vmcountup,expr `sudo /opt/xensource/bin/xe vm-list | grep running | wc –l` - 1
                          UserParameter=xe.vmcountdown,sudo /opt/xensource/bin/xe vm-list | grep halted | wc –l
                          svr-zen5[xx] # cp /etc/sudoers /etc/sudoers.orig
                          svr-zen5[xx] # vi /etc/sudoers
                          #Defaults requiretty
                          # User privilege specification
                          zabbix ALL = NOPASSWD: /opt/xensource/bin/xe vm-list
                          svr-zen5[xx] # cp /etc/rc.d/init.d/zabbix_agent \
                          /etc/rc.d/init.d/zabbix_agent.orig
                          svr-zen5[xx] # vi /etc/rc.d/init.d/zabbix_agent
                          #!/bin/sh
                          # Zabbix agent start/stop script.
                          # Written by Alexei Vladishev <[email protected]>.
                          PATH=/bin:/usr/bin:/sbin:/usr/sbin:/home/zabbix/bin
                          DAEMON=/usr/local/zabbix/bin/zabbix_agentd
                          CONFIG=/etc/zabbix/zabbix_agentd.conf
                          NAME=zabbix_agentd
                          DESC="Zabbix agent"
                          PID=/var/tmp/$NAME.pid
                          test -f $DAEMON || exit 0
                          set -e
                          case "$1" in
                          start)
                          echo "Starting $DESC: $NAME"
                          $DAEMON -c $CONFIG
                          stop)
                          echo "Stopping $DESC: $NAME"
                          ps -ef| grep -iv grep | grep $NAME|awk '{print$2}'| xargs kill
                          restart|force-reload)
                          # If the "reload" option is implemented, move the "force-reload"
                          # option to the "reload" entry above. If not, "force-reload" is
                          # just the same as "restart".
                          echo -n "Restarting $DESC"
                          sleep 2
                          $DAEMON -c $CONFIG
                          N=/etc/init.d/$NAME
                          # echo "Usage: $N {start|stop|restart|force-reload}" >&2
                          exit 1
                          esac
                          exit 0
                          svr-zen5[xx] # chmod 755 /etc/init.d/zabbix_agent
                          svr-zen5[xx] # cp /etc/rc.d/rc.local /etc/rc.d/rc.local.orig
                          svr-zen5[xx] # vi /etc/rc.d/rc.local
                          add the following rule:
                          /usr/local/zabbix/bin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf
                          svr-zen5[xx] # cp /etc/sysconfig/iptables /etc/sysconfig/iptables.orig
                          svr-zen5[xx] # vi /etc/sysconfig/iptables
                          # Firewall configuration written by system-config-securitylevel
                          -A RH-Firewall-1-INPUT -m state --state NEW -m udp -p udp --dport 694 -j ACCEPT
                          -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 22 -j ACCEPT
                          -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 80 -j ACCEPT
                          -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 443 -j ACCEPT
                          -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 6600 -j ACCEPT
                          -A RH-Firewall-1-INPUT -j REJECT --reject-with icmp-host-prohibited
                          COMMIT
                          svr-zen5[xx] # service iptables restart
                          svr-zen5[xx] # rm –rf /tmp/zabbix*
                          svr-zen5[xx] # /etc/init.d/zabbix_agent start
                          hope this helps
                          • elvar
                            • Feb 2008
                            • 226
                            Thanks to all who posted info on getting the zabbix agent working on XenServer. It's working great so far!
                            Kind regards,
                            • elvar
                              • Feb 2008
                              • 226
                              #15
                              Anyone been able to compile Zabbix Agent 1.8.3 inside the XenServer 5.6 SDK VM and get it to run? When I run it on my Xenserver 5.6 it crashes...
                              [root@xs01 init.d]# /usr/local/sbin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf
                              Segmentation fault
                              *** UPDATE ***
                              Changed ownership of /usr/local/sbin/zabbix_agentd to zabbix:zabbix and it runs fine.
                              *** UPDATE 2 ***
                              If I run as user zabbix it doesn't segfault. If I run as root it segfaults.
