anyone want to share their zabbix agent compiled for XenServer?
Citrix xenserver 5.5
So, I have the agent compiled and running... Using Xen SDK 5.6 and 1.8.2 agent...
Problem is I can't get the xenserver to talk to zabbix
Get value from agent failed: *** Cannot connect to [192.168.5.X]:10050 [No route to host]
Any ideas?
iptables --list
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:10050
I can ping the XenServer but I can't telnet to it.Last edited by Axilla; 28-08-2010, 00:29.Comment
Using "xe host-data-source-list" and "xe host-data-source-query" I made some basic UserParameter for xenserver below.
UserParameter=xe.vmcountup,sudo /opt/xensource/bin/xe vm-list | grep running | wc -l
UserParameter=xe.vmcountdown,sudo /opt/xensource/bin/xe vm-list | grep halted | wc -l
UserParameter=xe.memory_total_kib,sudo /opt/xensource/bin/xe host-data-source-query data-source=memory_total_kib
UserParameter=xe.memory_free_kib,sudo /opt/xensource/bin/xe host-data-source-query data-source=memory_free_kib
UserParameter=xe.xapi_memory_usage_kib,sudo /opt/xensource/bin/xe host-data-source-query data-source=xapi_memory_usage_kib
UserParameter=xe.xapi_free_memory_kib,sudo /opt/xensource/bin/xe host-data-source-query data-source=xapi_free_memory_kib
UserParameter=xe.xapi_live_memory_kib,sudo /opt/xensource/bin/xe host-data-source-query data-source=xapi_live_memory_kib
UserParameter=xe.xapi_allocation_kib,sudo /opt/xensource/bin/xe host-data-source-query data-source=xapi_allocation_kib
UserParameter=xe.cpu3,sudo /opt/xensource/bin/xe host-data-source-query data-source=cpu3
UserParameter=xe.cpu2,sudo /opt/xensource/bin/xe host-data-source-query data-source=cpu2
UserParameter=xe.cpu1,sudo /opt/xensource/bin/xe host-data-source-query data-source=cpu1
UserParameter=xe.cpu0,sudo /opt/xensource/bin/xe host-data-source-query data-source=cpu0
UserParameter=xe.loadavg,sudo /opt/xensource/bin/xe host-data-source-query data-source=loadavg
I will try to write more for xe vm-data-source-list and xe vm-data-source-query and update at http://slog.carlheaton.co.uk/index.p...k-in-progress/Comment
[Solved] Install zabbix agent on XenServer 5.6
I found this guide and it seems to work
